Packet tracer
azux14
Frequent Visitor
Frequent Visitor
Hello all,
I hope someone can assist me with my problem.
I've created a network in Packet tracer where all (6 departments) see each other + server + router + printers.
The requirement is I create a network where only PCs within each department see each other + server + router + printers. I'm having trouble setting this up can someone assist in configuring the set up please?
I'm also having trouble configuring the firewall.
The requirements are:
1GBPS speeds
IPs must be static
Star topology
Network must be segmented using subnetting and/or VLANs.
Computers cannot see computers in other departments but can see printer + router + server + firewall.
I'm attaching my Packet tracer file with existing setup and configuration.
Thank you I would really appreciate some help or guidance.
2 Accepted Solutions
luis_cordova
Hi @azux14 ,
I have reviewed your exercise and have made some changes to meet your requirements,
I have separated by VLAN from the department and assigned addresses to each VLAN.
All VLANs have their gateway in the router, so in the router I have applied an ACL that filters the traffic between them.
I enclose my progress.
Georg Pauwen
here is the final version based on the requirements you have sent. I have changed some IP addressing, cleaned up the access lists, and configured the ports on the switches. Review it so you understand what is going on...
5 Replies 5
luis_cordova
Hi @azux14 ,
Thanks a lot Luis, I appreciate your help with this 🙂 I will now use your example to teach myself on how to configure the network correctly myself.
Georg Pauwen
Thanks a lot Georg, that is brilliant ! I have reviewed it and understand what's going on now.
Should the Firewall be visible by all computers? If it should be visible then can I do the following to add it and nothing else:
ip access-list extended VLAN10
permit ip 192.168.1.0 0.0.0.63 host 192.168.1.4
permit ip host 192.168.1.4 192.168.1.0 0.0.0.63
ip access-list extended VLAN20
permit ip 192.168.1.64 0.0.0.15 host 192.168.1.4
permit ip host 192.168.1.4 192.168.1.64
etc for all 6 VLANs?
Thanks again ! Much appreci
Thanks again ! Much appreciated
