packet
trent16
IP ADDRESS  172.16.20.0/21 100 devices and 192.168.100.0/24 50 devices have to use second address for 3rd subnet
Leg A
router 172.16.20.1 255.255.255.128
problem is 3rd subnet 192.168.100.193 255.255.255.252
Server 172.16.20.2 IPV4  255.255.255.128 SUBENT  172.16.20.1DEFAULT
Leg B packet
Router 192.168.100.129 255.255.255.192
3 subnet where I get my problem with the over lap 192.168.100.194 255.255.255.252
SERVER
192.168.100.130 IPV4  255.255.255.192 SUBNET  192.168.100.129 DEFAULT
asking for some help.
The tag on here is wrong
15 Replies 15
Georg Pauwen
what exactly is your question ? Which subnets do you need, where is the overlap ? Please clarify.
The 3rd subnet is where it (over laps) where and how I have no clue.
leg A I have on the router
and leg  B I have
192.168.100.193 255.255.255.252 and 192.168.100.194 255.255.255.252 are the two host addresses in subnet 192.168.100.192/30.
It is unclear what your problem is...
Yes so this is the question for the assignment
- *Leg A*
- 172.16.20.0/21 Device addresses required 100
- VLAN 10
- *Leg B*
- 192.168.100.0/24 Device addresses required 50
And my 3rd sub net "over laps"
192.168.100.0/24 host a host range of 192.168.100.1 thru 192.168.100.254. So 192.168.100.192/30 is part of that range.
If you need to use 192.168.192.30/30, you need to use e.g. 192.168.100.0/25. This includes the host range 192.168.100.1 thru 192.168.100.126.
Yes 1-126 and my second one is
129-190
Now to my 3rd which changes to a /30 I have 193-194 is the router to router
connection
192.168.100.128/26 and 192.168.100.192/30 do not overlap.
I dont know what it is .
Reza Sharifi
What is your question?
It is not allowing me to input 3rd subnet it is saying it is over lapping
You are probably configuring the wrong mask somewhere and that is why you see the over-lapping message.
Can you post the entire config using "sh run"?
Yes I can give me one moment
LEG_B>en
LEG_B#sh run
Building configuration...
Current configuration : 738 bytes
version 12.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname LEG_B
ip cef
no ipv6 cef
This is what I have for the subnetting this is my subneting what I have imputed
for LEG A
                       Device range         broadcast
172.16.20.0        1-126                    127
what I put into router 1 LEG A
ip addr  172.16.20.1  255.255.255.128
no sh
int s0/0/0
ip addr 192.168.100.193 255.255.255.252      3RD SUBNET
Now for my server on leg A
172.16.20.2 IPV4
255.255.255.128 SUBNET
172.16.20.1 DEFAULT
now for my second subnet for LEG B
192.168.100.0/24    50 DEVICES
                                DEVICE RANGE      BROADCAST
192.168.100.128        129-190                   191
ROUTER LEG B
IP ADDR 192.168.100.129  255.255.255.192
NO SH
INT S0/0/0 192.168.100.194 255.255.255.252    THIS IS WHERE THE " OVER LAP " IS IN MY 3RD SUBNET
SERVER LEG B
