Cisco Catalyst C1000 bluetooth configuration
Russell in NY
I've got a C1000-16P-2G-L that I normally configure my Mac with a console cable using SecureCRT.
I'd like to use an Asus USB-BT400 bluetooth dongle.  So I connected the dongle to the switch, and paired it with the Mac.  I get what you see below.  I've contacted Asus, and I was told that the dongle doesn't come with a PIN.
So how do I set the code on the Cisco?
It does not appear that there is a code. Just press enter after entering the username and password.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst1000/hardware/installation/8_16_port_hig/b_c1000_8_16_hig.pdf
If your device supports Bluetooth, it loads with the initial setup tasks preconfigured. Connect your PC to the
device using Bluetooth. In your Web browser, enter the IP address 172.16.0.1. Enter the following default
credentials: username: cisco, password: cisco and press Enter.
Mark Elsen
 - Check if these guidelines apply to your platform too :
            https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9500/software/release/16-12/configuration_guide/int_hw/b_1612_int_and_hw_9500_cg/configuring_an_external_usb_bluetooth_dongle.html#id_111571
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Unfortunately they do not.  I'm running IOS 15.2(7)E3.
