packets and frames
carl_townshend
Hi all, when people talk about packets and frames, are they the same thing ? also what would be classed as normal amount of packets per second on a lan ?
5 Replies 5
mohammedmahmoud
Level 11
Level 11
Frame = Layer 2 header + packet + layer 2 trailer. When talking about layer 2 devices we always refer to frames.
Packet = IP header + datagram. When talking about layer 3 devices we always refer to packets.
They are sometimes used interchangeably but technically they are different.
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
So if the frame stays on layer 2 its still a frame, and when it crosses a router it adds ip header info so its then called a packet ??
We can think of it as the Frame contains the packet inside it as its payload, as long as the frame is layer 2 switched only the frame header is checked, but if the frame paths over a router, the router will need to decapsulate the frame in order to be able to check the packet header.
NOTE: The frame is constructed in the first place after the packet is fully structured with its ip header.
HTH,
Mohammed Mahmoud.
pciaccio
Level 4
Level 4
It is:
S = Segment = Layer 4
P = Packet = Layer 3
F = Frame = Layer 2
Hope this helps...Please rate...
B = Bit = Layer 1 (1's and 0's)
(just for completeness)
