Packets going to Gateway MAC instead of host MAC in same subnet
dbgreekas
I have a strange situation:
Host A is physical and connected to a switch port directly
Host B is virtual (VMWARE) and is on a vSwitch which is connected directly to the same switch as host A
Spanning the ports these hosts use I am finding something strange:
If some other host C,D, or F pings these I get the expected captures of seeing the source and destination hosts macs.
When looing at traffic between Host A and Host B they are using the MAC of the default gateway to communicate as if they don't think they are on the same subnet.
However I have reviewed the config of each twice
- Both have the correct subnet IP and mask
- Both have each others MAC in their arp cache
Any tips as to why this might happen? I am having intermittent connectivity issues between them, and have replaced the cabling and changed the switch ports already... They only seem to have trouble communicating with each other on occasion.
5 Replies 5
cadet alain
are they in the same VLAN?
Regards.
Alain.
They should both be in the "Default" vLan however as we all know "Default" means something differnet to each vendor "no tag, 0 or 1"
There is no explicit tagging begin done in VMware and both ports are in their default mode and when doing a listing on vLan membership on the cisco switch both both appear to be members of VLAN 1 as expected.
can you post sh interface switchport output for the 2 ports.
Alain.
show interface GigabitEthernet 0/17 switchport
Switchport: Enabled
Administrative Mode: dynamic auto
Operational Mode: static access
Administrative Trunking Encapsulation: negotiate
Operational Trunking Encapsulation: native
Negotiation of Trunking: On
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Administrative Native VLAN tagging: enabled
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk associations: none
Administrative private-vlan trunk mappings: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: false
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Appliance trust: none
show interface GigabitEthernet 0/9 switchport
Switchport: Enabled
Voice VLAN: none
Protected: false
Root cause was a static route on the windows host which had two nics in the same subnet.
