Packets input or output in switch 2960
tantn6001
Hi all,
How to know have packets input or output of one port in switch 2960 Catalyst. Thanks you!
Sarbjit-2014
Port mirror on a switch port, then run Wireshark on PC/Laptop.
Kind Regards.
Thank for your answer.
I have some problems involved Cisco Catalyst 2960 Switch.
I am using a device which includes Marvell PHY chip 88E1111. The device can send and receive PTP packet to and from my PC.
Now, I want to connect the device and the PC to Cisco Catalyst 2960 Switch, which will help me trace all of packets in the network . The test scenario is below:
-          Switch: Cisco Catalyst 2960
-          Tracer: Wireshark software
-          PC: Windows 7-64 bit, plugging in Switch port 1 (interface 1)
-          Device: FPGA board, plugging in Switch port 2 (interface 2),
operating mode: 1000Mbps, Fullduplex, no auto-negotiation, no auto power efficient-ethernet.
-          Interface 2 of the Switch is static set by the device’s MAC
address , which ensures the Switch known the device’s MAC.
I suffered a problem. Although the RJ45 TX status led are on, there is not any packet sent to the Switch. I have no idea in this case.
Could you give me an advise please.
