Cisco 6500 %SYS-SP-2-MALLOCFAIL: Memory allocation and Module Pwrdown
realshiro
I found log as below , what's the root cause ?
But now everything is comeback with reload the box.
------------------ show module ------------------
Mod MAC addresses                       Hw    Fw           Sw           Status
  1  0017.59f4.f440 to 0017.59f4.f46f   1.5   12.2(14r)S5  12.2(18)SXE6 Ok
  2  0017.9453.49c4 to 0017.9453.49f3   2.3   12.2(14r)S5  12.2(18)SXE6 Ok
  3  0017.e0b9.800c to 0017.e0b9.800f   2.2   12.2(14r)S5  12.2(18)SXE6 PwrDown
  4  0017.e0b9.6c3c to 0017.e0b9.6c3f   2.2   12.2(14r)S5  12.2(18)SXE6 PwrDown
  5  0013.c43a.f734 to 0013.c43a.f737   5.2   8.4(2)       12.2(18)SXE6 Ok
  7  0017.95a3.b326 to 0017.95a3.b32d   4.0   7.2(1)       3.2(1)       Ok
  8  0018.197e.221a to 0018.197e.2221   6.1   7.2(1)       5.0(2)       Ok
Mod Sub-Module                  Model              Serial        Hw     Status
  1 Centralized Forwarding Card WS-F6700-CFC       SAL1021PAZL   2.0    Ok
  2 Centralized Forwarding Card WS-F6700-CFC       SAL1019MFB6   2.0    Ok
  3 Centralized Forwarding Card WS-F6700-CFC       SAL1011G9XY   2.0    PwrDown
  4 Centralized Forwarding Card WS-F6700-CFC       SAL09391R9E   2.0    PwrDown
  5 Policy Feature Card 3       WS-F6K-PFC3B       SAL1020NATD   2.3    Ok
  5 MSFC3 Daughterboard         WS-SUP720          SAL1020MXCE   2.5    Ok
  8 IDS 2 accelerator board     WS-SVC-IDSUPG      ADEI61601174  2.4    Ok
show log
-Process= "DiagCard8/-1", ipl= 0, pid= 62
-Traceback= 4017B2A8 4017E828 40883454 4086DAC8 40874484 4087237C 40872190 40193958 40193944
Mar 27 14:56:43: %SYS-SP-2-MALLOCFAIL: Memory allocation of 5768 bytes failed from 0x4088344C, alignment 8
Pool: Processor  Free: 349312  Cause: Memory fragmentation
Alternate Pool: None  Free: 0  Cause: No Alternate pool
-Process= "DiagCard7/-1", ipl= 0, pid= 31
-Traceback= 4017B2A8 4017E828 40883454 4086DAC8 40874484 4087237C 40872190 40193958 40193944scp_fpoe_req: memory allocation error, subopcode=13, count=1
Mar 27 15:00:57: %SYS-SP-2-MALLOCFAIL: Memory allocation of 5768 bytes failed from 0x4088344C, alignment 8
Pool: Processor  Free: 320136  Cause: Memory fragmentation
------------------ show process memory ------------------
Processor Pool Total:  396081504 Used:   72497944 Free:  323583560
      I/O Pool Total:   67108864 Used:   10418768 Free:   56690096
 PID TTY  Allocated      Freed    Holding    Getbufs    Retbufs Process
   0   0   85845488   14694808   68388552          0          0 *Init*
   0   0       3384 3608082936       3384          0          0 *Sched*
   0   0 3603507336 4039919552    1503656    9841264      75552 *Dead*
   1   0    4433280    4431792      35104          0          0 Chunk Manager
   2   0        192        192       4024          0          0 Load Meter
   3   0     179024 1827956488      21056      31416    1052744 OSPF Hello
   4   0          0      17136       7040          0          0 DHCPD Timer
   5   0          0       5128       7064          0          0 Check heaps
   6   0    8443336    6991440       7024    2083620    1941296 Pool Manager
   7   0        192        192       7024          0          0 Timers
   8   0 2101377608 3184839112    1509960          0       2464 ARP Input
   9   0          0          0       7024          0          0 AAA_SERVER_DEADT
  10   0        192        192       7024          0          0 AAA high-capacit
  11   0   16954336   14610312    2351416          0          0 Entity MIB API
  12   0          0          0       7024          0          0 IFS Agent Manage
  13   0          0          0       7024          0          0 IPC Dynamic Cach
  14   0      48464      42784      12664          0          0 PF_Split Sync Pr
  15   0      21384          0       7024          0          0 IPC Periodic Tim
  16   0          0          0       7024          0          0 IPC Deferred Por
  17   0    2212272     135280     125800          0          0 IPC Seat Manager
  18   0          0          0       7024          0          0 IPC Stdby Update
  19   0        192        192       7024          0          0 DDR Timers
  20   0        192        192      13024          0          0 Dialer event
  21   0        192        192       7024          0          0 Serial Backgroun
  22   0 1568030944 1568076448       7024          0          0 EnvMon
  23   0          0          0       7024          0          0 Compute SRP rate
  24   0      10056          0      20000          0          0 EEM ED Syslog
  25   0     168424      46352      86456          0          0 rf proxy rp agen
  26   0          0          0       7024          0          0 HC Counter Timer
  27   0          0          0       7024          0          0 SERIAL A'detect
  28   0          0          0       7024          0          0 Snmp ICC Process
  29   0      88568      27264      15984          0          0 Cat6k SNMP
  30   0       3768     225864      10600          0          0 Cat6k SNMP Trap
  31   0          0          0       7024          0          0 Dynamic ARP Insp
  32   0          0          0       7024          0          0 Critical Bkgnd
  33   0    1817424      29672     669312          0          0 Net Background
  34   0       1744        192      13024          0          0 Logger
  35   0        192      59400      10024          0          0 TTY Background
  36   0          0  109508856       7024          0          0 Per-Second Jobs
  37   0          0    2710528       7024          0          0 Per-minute Jobs
  38   0          0          0       7024          0          0 PF Sync process
  39   0        384        520       7024          0          0 RPC rf_rfmib_not
  40   0     195336 1383593368      53952          0          0 Env action
  41   0        192        192       7024          0          0 Flash ICC Server
  42   0        168          0       7192          0          0 itasca
  43   0       2200       2200       7024          0          0 EOBC Monitor Pro
  44   0      43856      43456       7024          0          0 RPC pf-split-rp
  45   0     160056     157720      10720          0          0 draco-oir-proces
  46   0      26624     148024      17760          0          0 RTR Scheduler
  47   0          0          0       7024          0          0 MWAM CONFIG ON S
  48   0     141632     169296       7192          0          0 svclc
  49   0        768        768       7024          0          0 RPC Sync
  50   0        384        520       7024          0          0 RPC rpc-slave-15
  51   0          0       1968       7024          0          0 SCP Multicast
  52   0          0          0       7024          0          0 RF CWAN HA Proce
  53   0          0          0       7024          0          0 CWAN HA VLAN SYN
  54   0          0          0       7024          0          0 CWAN IF EVENT HA
  55   0          0          0       7024          0          0 CWAN APS HA Proc
  56   0          0          0       7024          0          0 CWAN SRP HA Proc
  57   0          0          0       7024          0          0 CWAN LTL Mgr HA
  58   0      26768        608       7024       5544          0 Heartbeat Proces
  59   0       7544      18232      11976          0          0 Const ICC reques
  60   0          0          0       7024          0          0 Const ICC event
  61   0          0          0       7024          0          0 Const ICC except
  62   0          0          0       7024          0          0 ICC Local Reques
  63   0          0   68006160       7024          0          0 ICC Async mcast
  64   0          0          0       7024          0          0 ICC_REQ Debug Pr
  65   0          0          0       7024          0          0 ICC FC Process
  66   0          0          0       7024          0          0 ICC FC Test Send
  67   0          0          0       7024          0          0 ICC FC Test Low
  68   0          0          0       4024          0          0 Inode Table Dest
  69   0          0          0       7024          0          0 IfIndex Bulk Syn
  70   0          0          0       7024          0          0 CWRP SPA TSM HA
  71   0          0          0       7024          0          0 Mistral Reset Pr
  72   0          0          0       7024          0          0 ECC correctable
  73   0      68104       3896      35096          0          0 PF_Init Process
  74   0      45056      24808      22296          0          0 RPC idprom-MP
  75   0          0          0       7128          0          0 Net Input
  76   0        192        192       7072          0          0 Compute load avg
  77   0       3136       1544       7024          0          0 RTTYS Process
  78   0          0          0       7024          0          0 BACK CHECK
  79   0      10056          0      17080          0          0 chkpt message ha
  80   0          0          0       7024          0          0 cpf_process_msg_
  81   0          0          0       7024          0          0 cpf_process_ipcQ
  82   0          0          0       7024          0          0 IPC Apps Task
  83   0      60104          0      67184          0          0 RADIUS
  84   0          0       8664       7096          0          0 AggMgr Process
  85   0       1152       1640       7024          0          0 SFF8472
  86   0          0          0       7024          0          0 Remote Console P
  87   0        192        192       7024          0          0 CWAN port channe
  88   0          0          0       7024          0          0 POS APS Event Pr
  89   0          0          0       7024          0          0 CWAN OIR Handler
  90   0          0          0       7024          0          0 DSX3MIB ll handl
  91   0          0          0       7024          0          0 FPD Management P
  92   0          0          0       7024          0          0 FPD Action Proce
  93   0          0          0       7024          0          0 spa_oir_audit_pr
  94   0       1808        384       8448          0          0 ACE_REQUESTS han
  95   0      16688          0      41712          0          0 ACE Tunnel Task
  96   0          0          0      25024          0          0 ACE VRF Task
  97   0          0          0       7024          0          0 CWAN CHOCX PROCE
  98   0          0          0       7024          0          0 HAL Mailbox
  99   0          0          0       7024          0          0 CWAN CHDSX PROCE
 100   0          0          0       7024          0          0 CT3 Mailbox
 101   0          0          0       7024          0          0 CE3 Mailbox
 102   0        192        192       7024          0          0 MIP Mailbox
 103   0          0          0       7024          0          0 vcq_proc
 104   0       7104          0       7104          0          0 Earl NDE Task
 105   0  163924608  163577120       7024      50820          0 esw_vlan_stat_pr
 106   0       2688       3064       7216          0          0 Gemini L3 forwar
 107   0          0          0       7024          0          0 CWRP SPA ATM OIR
 108   0          0          0       7056          0          0 ACE event
 109   0          0          0       7024          0          0 ACE HAPI
 110   0          0          0       7024          0          0 ACE policy loade
 111   0        192        192       7024          0          0 AAA Server
 112   0          0          0       7024          0          0 AAA ACCT Proc
 113   0          0          0       7024          0          0 ACCT Periodic Pr
 114   0 3562610112 3562392984      63328          0          0 CDP Protocol
 115   0     747080     744104      12088          0          0 IP RTR Probe Max
 116   0        168          0       7192          0          0 CEF Scanner
 117   0        192        192       7024          0          0 AAA Dictionary R
 118   0          0          0       7024          0          0 DHCP Snooping
 119   0   56860656  797953784     869192     332108      36764 IP Input
 120   0        192        192       7024          0          0 TurboACL
 121   0        192        192       7024          0          0 MOP Protocols
 122   0          0          0       7024          0          0 PPPATM Session d
 123   0        192        192      13024          0          0 PASVC create VA
 124   0     752664     749704      13096          0          0 IP RTR Probe Max
 125   0          0          0       7024          0          0 HDLC HA
 126   0          0          0       7024          0          0 ARP HA
 127   0        408        216       7216          0          0 Spanning Tree
 128   0          0          0       7024          0          0 AC Mgr
 129   0          0          0      13024          0          0 SSS Manager
 130   0          0          0      13024          0          0 SSS Test Client
 131   0     519448     186128     354624          0          0 SW VLAN RP
 132   0         96         88       7120          0          0 const ipfib per-
 133   0       3240        272       9992          0          0 Const MPLS RP pr
 134   0       7264        608      13120          0          0 Const Rate Limit
 135   0          0          0       7024          0          0 CWAN LTL manager
 136   0   82089144   82084864      17328          0          0 SSH Event handle
 137   0     123928     515992      10312          0          0 CEF RP IPC Backg
 138   0     467088     495768      71320          0          0 HWIF QoS Process
 139   0        192        192       7024          0          0 IP Hdr Comp Proc
 140   0     755960     752992      13072          0          0 IP RTR Probe Max
 141   0          0          0       7024          0          0 MLS FIB RP
 142   0        192        192       7024          0          0 mcast_rp_icc Pro
 143   0        192        192       7024          0          0 QOS Stats Export
 144   0 1487247328 1487247328       7024          0          0 QOS Stats Gather
 145   0        392        280       7224          0          0 cfib v6 per pref
 146   0          0          0       7024          0          0 LSP Tunnel FRR
 147   0          0          0       7024          0          0 MPLS Auto-Tunnel
 148   0          0          0      10024          0          0 IP IRDP
 149   0          0          0       7024          0          0 PPP IP Add Route
 150   0          0          0       7024          0          0 ATM HA
 151   0          0          0       7024          0          0 SNMP Timers
 152   0          0          0       7024          0          0 Inspect Timer
 153   0          0          0       7024          0          0 Authentication P
 154   0      14744       2736      11576          0          0 IP Background
 155   0   84780544   71423280     142776          0          0 IP RIB Update
 156   0          0          0       7024          0          0 CHKPT DevTest
 157   0          0          0       7024          0          0 Socket Timers
 158   0 3045325760 3045203408      33456          0          0 DHCPD Receive
 159   0          0      13472       7024          0          0 IP Cache Ager
 160   0        880        192       7024          0          0 Adj Manager
 161   0          0          0       7024          0          0 FR HA
 162   0          0          0       7024          0          0 HTTP Timer
 163   0       6552  212299976      13208          0          0 TCP Timer
 164   0 3648045496     208984      16072          0          0 TCP Protocols
 165   0      73328       7608      43224          0          0 IPC LC Message H
 166   0          0          0       7024          0          0 PPP HA
 167   0          0          0       7024          0          0 SLB CF process
 168   0     583872        480     569056          0          0 CEF process
 169   0        384        192       7216          0          0 DVMRP Timers
 170   0          0          0      25024          0          0 COPS
 171   0 1091537256 1023641568      21496          0          0 L3 Manager
 172   0   23501864 2012824240     869376          0          0 FM core
 173   0          0          0       7024          0          0 Probe Input
 174   0          0          0       7024          0          0 RARP Input
 175   0          0          0       7024          0          0 PAD InCall
 176   0        192        192      13024          0          0 X.25 Background
 177   0          0          0       7024          0          0 X.25 Encaps Mana
 178   0          0          0       7024          0          0 CWAN QinQ tasks
 179   0        192        192       7024          0          0 HIDDEN VLAN Proc
 180   0          0          0       7024          0          0 CWAN-RP SCP Proc
 181   0      21408          0      14216          0          0 CWAN-RP SCP Inpu
 182   0        616        320       7320          0          0 LSP Verification
 183   0          0          0       7024          0          0 VFI Mgr
 184   0          0          0       7024          0          0 AToM manager
 185   0        192      17984       7024          0          0 AToM switching m
 186   0          0          0       7024          0          0 AToM LDP manager
 187   0      14736        192      11512          0          0 L2TRACE SERVER
 188   0       1272       2304       7024          0          0 mfib-const-rp Pr
 189   0       5144        248      12168          0          0 MLSM-CC Process
 190   0        192        192       7024          0          0 MWAM_CONSOLE Tim
 191   0        192        192       7024          0          0 CWPA QoS
 192   0        192        192      61024          0          0 SIP10G QM Proces
 193   0        656        272       7104          0          0 Const TCAM Mgr R
 194   0          0          0       7024          0          0 Crypto HW Proc
 195   0          0          0       7024          0          0 IPv6 CEF process
 196   0        192        192       7024          0          0 ATIP_UDP_TSK
 197   0          0          0       7024          0          0 IDS Timer
 198   0        192        192       7024          0          0 Tag Input
 199   0          0          0       7024          0          0 LFIB FRR IOS
 200   0          0          0       7024          0          0 LDP Background
 201   0        192        192       7056          0          0 AAA Cached Serve
 202   0        192        192       7024          0          0 LOCAL AAA
 203   0          0          0       7024          0          0 Crypto Support
 204   0          0          0      13024          0          0 Encrypt Proc
 205   0 2597247464 2597246328      10160          0          0 Key Proc
 206   0       7744       1344      15424          0          0 Crypto CA
 207   0          0          0       9024          0          0 Crypto PKI-CRL
 208   0        344          0       7368          0          0 CCSWVOICE
 209   0          0          0       7024          0          0  Laminar Icc Eve
 210   0        192        192      13024          0          0 SLB Main CPU pro
 211   0        176        488      25024          0          0 Crypto ACL
 212   0          0          0       7024          0          0 CRYPTO QoS proce
 213   0      24960          0      37984          0          0 Crypto Delete Ma
 214   0      10728        192      23560          0          0 Crypto IKMP
 215   0     183624     142784      53072          0          0 IPSEC key engine
 216   0          0          0       7024          0          0 IPSEC manual key
 217   0        192        192       7024          0          0 RADIUS TEST CMD
 218   0        192        192       7024          0          0 AAA SEND STOP EV
 219   0          0          0       7024          0          0 L3MM Process
 220   0          0          0       7024          0          0 Syslog Traps
 221   0        192        328       7080          0          0 RPC aapi_rp
 222   0     138944      69360      76256          0          0 RPC capi_rp
 223   0        192        328       7024          0          0 RPC chapi_rp
 224   0        192        328       7024          0          0 RPC dot1x_aaa_rp
 225   0        192        328       7024          0          0 RPC epld_sp2rp
 226   0      27344      27480       7024          0          0 RPC idbman_sp2mp
 227   0        168          0       7192          0          0 LC Registry Expo
 228   0       2080        632       7024          0          0 Logger ICC Proce
 229   0 2286185272 2286027320     103096      11396          0 RPC online_diag_
 230   0        192        328       7024          0          0 RPC online_wan_d
 231   0     424712     253640     158864          0          0 RPC pagp_switch_
 232   0        192        328       7024          0          0 RPC pm_switch_sp
 233   0       5248        328      12080          0          0 RPC psecure_rp
 234   0       2336       2472       7024          0          0 RPC pt_switch_sp
 235   0        192        328       7024          0          0 RPC qnq_switch_s
 236   0        192        328       7024          0          0 RPC rf_cli_sp2rp
 237   0          0          0       7024          0          0 SONET Traps
 238   0        192        192       7024          0          0 VTPMIB EDIT BUFF
 239   0        192        328       7024          0          0 RPC snmp_notify
 240   0       8624       8568       8952          0          0 RPC snmp_stackli
 241   0        192        328       7024          0          0 RPC span_switch_
 242   0   40058792   40058928       7024          0          0 RPC stp_sp2mp_ap
 243   0        168          0       7240          0          0 DHCPD Database
 244   0        392        392       7088          0          0 Module enable-di
 245   0      50488      23672      33976          0          0 RPC c6k_power_rp
 246   0  203882824 3115251944       7024      17556          0 RPC c6k_rp_envir
 247   0          0          0       7024          0          0 CONST AFL
 248   0          0          0       7024          0          0 Const FIB MAC
 249   0      20520      18808       7024          0          0 Constellation Ba
 250   0        192        192       7024          0          0 Rommon upgrade p
 251   0        192        192       7024          0          0 RP Error Detecti
 252   0        192        328       7024          0          0 RPC error_detect
 253   0      10224          0      17248          0          0 RP L2 Applicatio
 254   0          0          0       7024          0          0 LACP-MP Process
 255   0      67848      68352       7192          0          0 Online Diag EEM
 256   0       5056          0      12080          0          0 PAgP-MP Process
 257   0        192        328       7024          0          0 RPC pclc_g2_agsm
 258   0     761320     761456       7024          0          0 RPC pclc_g2_fw_r
 259   0        192        328       7024          0          0 RPC pikachu_rp
 260   0    8152792 2605243888     360496       2156          0 IGMP Input
 261   0  351025264    5728200       7264          0          0 RPC pm-mp
 262   0          0          0       7024          0          0 PM Callback
 263   0 1765825960 1765309208     289504     122584          0 Port manager per
 264   0          0          0       7024          0          0 Max CPU utilizat
 265   0      76408     151424      61384          0          0 QM Process on RP
 266   0        192       2280      61024          0          0 QM Reply Process
 267   0      60320       3408       7024          0          0 RPC lcc_sp
 268   0       2496       2632       7024          0          0 RPC fabman_sp
 269   0        192        192       7024          0          0 rp to lc clock u
 270   0          0          0      10056          0          0 Connection Mgr
 271   0       5520       5256       7288          0          0 EC-Card-Cfg
 272   0      90608      51248       7024          0          0 RPC sw_vlan_rp
 273   0        640        776       7024          0          0 RPC udld_rp
 274   0     745992     520456       7024          0          0 RPC vtp_const_ap
 275   0      10296        664      17320          0          0 EEM Server
 276   0       9960        192      16128          0          0 EEM Policy Direc
 277   0       9408          0      19432          0          0 EEM ED CLI
 278   0       9408          0      19432          0          0 EEM ED Counter
 279   0       9408          0      19480          0          0 EM ED GOLD
 280   0       9408          0      19432          0          0 EEM ED Interface
 281   0       9408          0      19432          0          0 EEM ED IOSWD
 282   0       9408          0      19432          0          0 EEM ED Memory-th
 283   0       9408          0      19432          0          0 EEM ED None
 284   0       9752        384      19776          0          0 EM ED RF
 285   0       9408          0      19432          0          0 EEM ED SNMP
 286   0       9408          0      19432          0          0 EEM ED Timer
 287   0        192        192       7024          0          0 CWAN Bridge task
 288   0          0          0       7024          0          0 DHCP Snooping Sw
 289   0 1135121184  603826784      97384      13552          0 PIM Process
 290   0        168          0       7192          0          0 Online Diag CNS
 291   0        168          0       7192          0          0 Online Diag CNS
 292   0          0         96       7024          0          0 VACL Logger
 293   0        168 2344988816       7192          0          0 Mwheel Process
 294   0          0          0       7024          0          0 NetFlow Agg Task
 295   0          0          0       7024          0          0 CWAN OIR IPC Rea
 296   0       5840       3760       7024          0          0 RTTYS Process
 297   0   81329648   81259480     691096          0          0 MLSM Process
 298   0          0          0       7024          0          0 PF Clock Process
 299   0 3631364152 3631354040       7024          0          0 MLSM Stat Proces
 300   0    2204304      30128      23752     538076       6160 Standby (HSRP)
 301   0     754816     751840      13000          0          0 IP RTR Probe Max
 302   0 3451294192 3451056072      13912          0          0 IP SNMP
 303   0 2487425416      76008      13024          0          0 PDU DISPATCHER
 304   0 1937713720  129257784     139824          0          0 SNMP ENGINE
 305   0 1310762040 1310852320      13480          0          0 SNMP ConfCopyPro
 306   0          0          0      13024          0          0 SNMP Traps
 307   0       3984        192       7512          0          0 NTP
 308   0 1371217088 3843195224      51648          0     169400 OSPF Router 10
 309   0     759968     756968      13032          0          0 IP RTR Probe Max
 310   0     763400     760376      13088          0          0 IP RTR Probe Max
 311   0     760312     757296      13104          0          0 IP RTR Probe Max
 312   0     746264     743120      13256          0          0 IP RTR Probe Max
 313   0     757624     754432      13328          0          0 IP RTR Probe Max
 314   0     750072     746864      13288          0          0 IP RTR Probe Max
 315   0     754232     751088      13184          0          0 IP RTR Probe Max
 316   0     757464     754312      13280          0          0 IP RTR Probe Max
 317   0 1012970184 1012956184      13184          0          0 IP RTR Probe Max
 318   0          0          0       7064          0          0 draco-oir-proces
 320   0          0          0       7160          0          0 draco-oir-proces
 321   2     535448     501384      44800          0          0 SSH Process
 322   3    7249928    7171696      81344          0          0 SSH Process
Boyan Sotirov
Memory allocation is usually a software problem. In your case it seems the system goes out of memory. It happens due to processess not freeing memory after it's being used.
Why this happens it's an interesting thing here...
Did you try with different interface cards if by any chance you have any spares?
The cards in slots 1-4 are the same model, but they're different hardware revisions though. And the one that are failing are with HW revision 2.2. It might be related. But we may also have a faulty interface card.
It would be also nice if you could test the interface cards in another chassis...
