packets per second
carl_townshend
Hi all, when monitoring a normal lan with around 150 to 200 pc's on it, what is the normal average pps on each port, ie for broadcasts etc. I could do with a amount to compare with.
cheers
andrew.prince
Level 11
Level 11
There are no numbers - every network is different.
You need to perform trend analysis to determine what's normal and what's not.
HTH>
I would like to know how to calculate trunk util betweeen access and dist layer , dist and core layer.
I've very limited access to cisco works.
Thanks, karthik
