09-24-2007 09:15 PM - edited 03-05-2019 06:40 PM
Hi All
Is it possible to configure pagp or lacp channels using more than one switch ie with 2 switches connected together (not in a stack) and using a port on each create a etherchannel? I have a requirement to diversify links but would like to channel the links up to get better bandwidth utilization.
Solved! Go to Solution.
09-24-2007 09:21 PM
HI Nhon,
If your requirement is this
sw1 (port 1)---(port 1) sw2
sw1 (port 2)---(port 2) sw2
it is very much possible and this is the way etherchannel muct be use.
But if your requirement is
sw1 (port 1)----(port 1) sw3
sw2 (port 1)----(port 2) sw3
this is not possible as of now as etherchannel cannot be split between 2 switches.
Ankur
*Pls rate all helpfull post
09-24-2007 09:21 PM
HI Nhon,
Ankur
