Passive ftp - forward port range on a 2821 router
nitronexion
Hi all,
Lately, I've been configuring our new 2821 router and the ftp part is causing me some serious headaches. I would really really appreciate any help ;)
So, to start from the beginning...
I'd like to give access from the internet to our ftp server using passive mode (active mode works fine)
For the moment, it goes as follows:
Ftp-data connections from client to server should use ports 40000-41000
the access-list includes :
permit tcp any host 212.68.206.34 eq ftp-data
permit tcp any host 212.68.206.34 range 40000 41000
inspection rule includes ftp
the problem is how to do a port forwarding from the external interface to the inside server.
I've added the following
ip nat inside source static tcp 192.168.x.x 40000 interface GigabitEthernet0/1 40000
till port 40010
and it's working fine. However, I need to forward the entire range 40000-4100. Is there a way to do this without adding all entries one by one?
Many thanks for your reply,
Elena
bwalchez
Level 4
Level 4
As you know that FTP server that communicates with CUE must support passive FTP requests. I think you can forward the entire range 40000-4100.
