Password Expiry Policy at catalyst Switches
Hi Team,
We need to configure password policy for the Cisco C1000/9200/9300/9500 without AAA model.
6 Replies 6
M02@rt37
Rising star
Rising star
Hello @Ajit Kumar Tripathi,
If you are using the Cisco Catalyst C1000/9200/9300/9500 switches without AAA model, you can configure a local user/password policy directly on the switches.
username [name] privilege [priv_level] secret/password [password]
Under line con/vty add the command "login local"
https://www.networkstraining.com/configuring-local-username-and-password-on-a-cisco-ios-router/
Best regards
******* If This Helps, Please Rate *******
Ben
Hi M02@rt37
thanks for your support,
But we need password expiry policy.
Hi @MHM Cisco World M02@rt37
Thanks for update
without AAA, this is not possible ?
Let make double check
Recognize Your Peers
