password recovery for 2960 without loosing configuration
shakeerali
I don't remember password for Cisco 2960 switch, now i want to recover the password. I have checked few documents but would like to know few things before following these steps.
1. Is password recovery procedure for Cisco 2960 switch is different from normal ctr+break then change the register method? As i am more confident of doing this procedure than  using mode button and then renaming the configuration file.
2. If i follow below procedure then hope it won't erase the configuration including vlans information.?
https://supportforums.cisco.com/discussion/11756896/cisco-switch-29603560-password-recovery-and-factory-default-mode-button
3. Pressing mode button is an alternate to using ctrl+break sequence? and long pressing of mode button does't effect anything.
4. Restarting the switch after pressing mode button (without making any changes) will go back to previous configuration (working condition).
Thanks.
Leo Laohoo
Password recovery for switches, like the Catalyst 2K and 3K, are far more simpler.    Read this:  Cisco Catalyst Fixed Configuration Layer 2 and Layer 3 Switches
I've posted a link above.  I'd recommend you read that one.  The link you've posted is about someone who wants to make a simple procedure look complicated.
Correct.  Get your mindset out of the password recovery of routers.  When you are dealing with some models of switches, it's the "Mode" button.  There are no "Mode" buttons in routers, hence, the Ctrl+Break key is required.
If you did NOT rename the configuration file, yes, the switch will reboot and load the existing configuration file.
If you renamed the configuration file, the switch will reboot.  Finding no configuration file, the switch will load the factory defaulted configuration.
Leo Laohoo
Thanks...!
