Password Recovery for CISCO 6509 Switch
Hi Friends,
I have one CISCO 6509 Switch in my store. I tired to login in that switch but couldnt.. Once it's booted it's asking me: rd: . Can any one help me to fix. Find the attachment. I recover the password by changing confreg value but that also failed. can any one help me.
Tamilvanan.S
9 Replies 9
Ganesh Hariharan
Hi Friends,
Tamilvanan.S
Hi Tamilvanan,
Check out the below link for password recovery procedure for 6500 series switches
http://www.ciscosystems.li/en/US/products/hw/switches/ps700/products_password_recovery09186a0080133fb1.shtml
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
Hi Ganesh,
I already tried this method. but once confreg changed it's not going thrg by pass mode. can you get it from my attachment.
Pls help me to get it fixied.
Tamilvanan.S
Hi Ganesh,
Tamilvanan.S
If you are in native IOS, the config-register you need to change is the one from the MSFC (RP).
When the 6500 is booting up it will start in the Switch Processor (SP), decompress the image and then you'll see:
*****  Changing ownership to route processor ******
Here is where you want to interrupt (ctrl + break) and change the register
Hope to help !!
Ganesh.H
Hi Ganesh,
Thanks a lot for ur reply.
I tried that method also. but it's falied. can u suggest some other method.
Tamilvanan.S
Can any one help me to recover the password. Pls find the attachment.
Tamilvanan.S
This is the only method from Cisco.  Can you please let us know WHY the process isn't working for you?
I believe you have tried a lot of stuff, and honestly i have never seen any of them not working. Either you are missing something or you are doing something wrong.
I would suggest open a TAC case and they will do it for you and if it doesnt work then you will get a replacement.
regards,
Varun
Many thanks Ganesh... It worked perfect for me today (crtl+break) while ownership on RP.
Ahmed...
ashirkar
Level 7
Level 7
Hi Tamilvanan
Did you check " remote command switch sh bootvar" command.
What boot variable value it is showing ?
Ashish
