password recovery for switch 2960
Ronenhazan
Currently Being Moderated
password recovery help
some bady can help me with password recovery switch 2960
that what i am doing and i get faill sll the time
what i am doing worng?
switch: flash_init
Initializing Flash...
flashfs[0]: 0 files, 1 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 32514048
flashfs[0]: Bytes used: 1024
flashfs[0]: Bytes available: 32513024
flashfs[0]: flashfs fsck took 9 seconds.
...done Initializing Flash.
Boot Sector Filesystem (bs) installed, fsid: 3
Setting console baud rate to 9600...
switch: load_helper
switch: dir flash
unable to stat flash/: no such device
switch: load_helper
switch: dir flash:
Directory of flash:/
32513024 bytes available (1024 bytes used)
switch: rename flash:config.text flash:config.text.old
rename: no such file or directory
switch: boot
Loading "flash:c2960-lanbase-mz.122-35.SE5/c2960-lanbase-mz.122-35.SE5.bin"...flash:c2960-lanbase-mz.122-35.SE5/c2960-lanbase-mz.122-35.SE5.bin: no such file or directory
Error loading "flash:c2960-lanbase-mz.122-35.SE5/c2960-lanbase-mz.122-35.SE5.bin"
Interrupt within 5 seconds to abort boot process.
Boot process failed...
switch:
Reza Sharifi
From the output you posted, it doesn't apear that you have any IOS image in the directory
You may want to use Xmodem to load a new IOS, if there isn't on the flash.
https://supportforums.cisco.com/community/netpro/network-infrastructure/switching/blog/2012/01/24/loading-an-ios-on-a-switch-via-xmodem
Password recovery router
Power cycle router
Press crtl-break
Type confreg 0x2142
reset
copy star run
all interfaces will be down
change passwords
conf t
config-register 0x2102
copy run star
reload
Password recovery Switch:
power cycle switch - depress mode button until port 1 led shows solid for about 2-3 secs
flash_int
load_helper
boot
dir flash:
rename flash:config.text flash:config.old
boot
rename flash:config.old flash:config.text
copy star run
change password
save config
reload
Booting from Flash:
dir bootflash:
Reset
Boot
Coying ios from TFTP into flash:
rommon x > set
    IP_ADDRESS=x.x.x.x
    IP_SUBNET_MASK=x.x.x.x
    DEFAULT_GATEWAY=x.x.x.x
    TFTP_SERVER=x.x.x.x
    TFTP_FILE=c2960-lanbase-mz.122-35.SE5/c2960-lanbase-mz.122-35.SE5.bin
set
tftpdnld
Note: D/G & TFTP server addresses are usually the same ip if copying  directly from another switch or router
res
Paul
Please don't forget to rate this post if it has been helpful.
Kind Regards
Paul
NOTE TO EVERYONE:  This is a duplicate post.
