PAT Config issue
jlajuarez
Level 2
Level 2
I have several issues with my PAT config. On the attached image of the topology:
1. Only hosts on network 10.0.1.0 / 25 can ping interface 128.10.10.2 / 24 (PAT is successful for this network)
2. Network 10.0.10.0 / 25 (VLAN) can ping 128.10.10.1 / 24, but cannot ping 128.10.10.2 / 24
3. The rest of the networks, whenever i ping 128.10.10.1 / 24 , it says destination host unreachable.
Here are the configurations i used in this topology.
R1(config)#int fa1/0
R1(config-if)ip nat inside
R1(config)#int s0/0/0
R1(config-if)#ip nat outside
R1(config-if)#exit
R1(config)#ip nat pool PATPOOL 128.10.10.1 128.10.10.1 netmask 255.255.255.0
R1(config)#ip route 0.0.0.0 0.0.0.0 s0/0/0
R1(config)#ACCESS-LIST 1 PERMIT 10.0.1.0 0.0.0.127
R1(config)#ACCESS-LIST 1 PERMIT 10.0.10.0 0.0.0.127
R1(config)#ACCESS-LIST 1 PERMIT 10.0.2.0 0.0.0.127
R1(config)#ACCESS-LIST 1 PERMIT 10.0.3.0 0.0.0.127
R1(config)#ACCESS-LIST 1 PERMIT 172.16.1.0 0.0.0.3 * in my first config, i did not include this, but result is still the same. this is my current config.
R1(config)#ACCESS-LIST 1 PERMIT 172.16.2.0 0.0.0.3
R1(config)#ACCESS-LIST 1 PERMIT 172.16.3.0 0.0.0.3
R1(config)#ip nat inside source list 1 pool PATPOOL overload
Show IP Nat Trans on Router0
Pro  Inside global     Inside local       Outside local      Outside global
icmp 128.10.10.1:29    10.0.1.6:29        128.10.10.2:29     128.10.10.2:29
icmp 128.10.10.1:30    10.0.1.6:30        128.10.10.2:30     128.10.10.2:30
icmp 128.10.10.1:31    10.0.1.6:31        128.10.10.2:31     128.10.10.2:31
icmp 128.10.10.1:32    10.0.1.6:32        128.10.10.2:32     128.10.10.2:32
Show IP route on Router0
     10.0.0.0/25 is subnetted, 4 subnets
C       10.0.1.0 is directly connected, FastEthernet1/0
O       10.0.2.0 [110/2] via 172.16.1.2, 00:55:33, FastEthernet0/0
O       10.0.3.0 [110/2] via 172.16.3.2, 00:55:33, FastEthernet0/1
C       10.0.10.0 is directly connected, FastEthernet1/0.10
     128.10.0.0/24 is subnetted, 1 subnets
C       128.10.10.0 is directly connected, Serial0/0/0
     172.16.0.0/30 is subnetted, 3 subnets
C       172.16.1.0 is directly connected, FastEthernet0/0
O       172.16.2.0 [110/2] via 172.16.1.2, 00:55:33, FastEthernet0/0
C       172.16.3.0 is directly connected, FastEthernet0/1
S*   0.0.0.0/0 is directly connected, Serial0/0/0
I also tried configuring the other interfaces in the router as IP NAT INSIDE but still the same result (this is just me experimenting).
What have I done wrong?
There is a default route on this router but ospf does not announce it to the rest of the neigbors, it's only known locally.
The best solution woukd be to add the following line to your ospf config:
router ospf 1
default-information originate
If you want some additional reading on the subject, please check the link below:
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094a74.shtml#typesofospfareas
regards,
Leo
15 Replies 15
cadet alain
As you are natting to 128.10.10.1 then the src ip add for POP router is 128.10.10.1 which is directly connected so he can reply.
If you want 10.0.2.0,10.0.3.0,10.0.20.0 and 10.0.30.0 to get natted you must put ip nat inside on f0/0 and f0/1
if the other networks are not NAT overloaded then their src ip add is not natted and if POP router hasn't got a default route  via its serial interface
he won't be able to reply back.
can you post: sh run int f1/0
In your routing table you have no route for them via ospf and your default route is pointing to s0/0/0 where they are not located
whether you put your network commands in ospf on the other routers or you put static routes to them pointing to next-hop on this router.
Regards.
Alain.
1. Nat inside was already configured on fa0/0 (172.16.1.1) and fa0/1 (172.16.3.1) and fa1/0 (10.0.1.1)
2. I think i have placed all other networks on overload, haven't i?
3. All routers have ospf configured in them.
Here is the show run on Router 0
interface FastEthernet0/0
ip address 172.16.1.1 255.255.255.252
ip nat inside
duplex auto
speed auto
interface FastEthernet0/1
ip address 172.16.3.1 255.255.255.252
ip nat inside
duplex auto
speed auto
interface Serial0/0/0
ip address 128.10.10.1 255.255.255.0
ip nat outside
clock rate 64000
interface FastEthernet1/0
ip address 10.0.1.1 255.255.255.128
ip nat inside
duplex auto
speed auto
interface FastEthernet1/0.10
encapsulation dot1Q 10
ip address 10.0.10.1 255.255.255.128
router ospf 1
log-adjacency-changes
network 172.16.1.0 0.0.0.3 area 0
network 172.16.3.0 0.0.0.3 area 0
network 10.0.1.0 0.0.0.127 area 0
network 10.0.10.0 0.0.0.127 area 0
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0/0/0
in the output of show ip route you gave there was no OSPF routes for 10.0.20.0, 10.0.30.0
I didn't say they weren't, I said they were not natted.
You are on packet tracer? can you do some debugs?
first clear nat table: clear ip nat translation *
then ping from 10.0.10.0/25 network -PC3 avec debug ip nat puis show ip nat trans
then do the same with ip nat inside configured on f1/0.10  it should solve 10.0.10.0/25 network problem
in your ACL remove all lines with 172.16.x.x   then do the same test from these subnets to see if they still not natted
and in that case(no natted) if you want your pings to succeed you must advertise these subnets to your NAT router otherwise how can he reply
Regards.
Oh yeah!!! There is no 10.0.20.0 or 10.0.30.0.. Haha...
Ok I will try to do what you just told me....
Bugger!!! I left the packet tracer file in office computer. Lol. Darn it... I'll do these things you told me as soon as i get my hands on the file.. Thank you so much for your time..  I'll reply again in this thread once i have done what you told me.. Till then...
Thanks..
Hey man..
Sorry this took a while.... I apologize...
After i have done what you have said...
so far 10.0.1.0 and 10.0.10.0 can now ping 128.10.10.2
Show IP Nat Trans result
R1#show ip nat trans
icmp 128.10.10.1:1     10.0.1.6:1         128.10.10.2:1      128.10.10.2:1
icmp 128.10.10.1:2     10.0.1.6:2         128.10.10.2:2      128.10.10.2:2
icmp 128.10.10.1:3     10.0.1.6:3         128.10.10.2:3      128.10.10.2:3
icmp 128.10.10.1:4     10.0.1.6:4         128.10.10.2:4      128.10.10.2:4
icmp 128.10.10.1:29    10.0.10.6:29       128.10.10.2:29     128.10.10.2:29
icmp 128.10.10.1:30    10.0.10.6:30       128.10.10.2:30     128.10.10.2:30
icmp 128.10.10.1:31    10.0.10.6:31       128.10.10.2:31     128.10.10.2:31
icmp 128.10.10.1:32    10.0.10.6:32       128.10.10.2:32     128.10.10.2:32
However, the rest of the networks on the other routers cannot ping the 128.10.10.1 interface on the router R1 (NAT router).
Pinging 128.10.10.1 with 32 bytes of data:
Reply from 10.0.3.1: Destination host unreachable.
Reply from 10.0.2.1: Destination host unreachable.
Ping statistics for 128.10.10.1:
    Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
Here is the new show run config on R1
ip nat inside
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
ip nat outside
clock rate 64000
ip nat inside
duplex auto
speed auto
ip nat inside
router ospf 1
network 10.0.20.0 0.0.0.127 area 0
network 10.0.30.0 0.0.0.127 area 0
network 10.0.2.0 0.0.0.127 area 0
network 10.0.3.0 0.0.0.127 area 0
ip classless
access-list 1 permit 10.0.1.0 0.0.0.127
access-list 1 permit 10.0.2.0 0.0.0.127
access-list 1 permit 10.0.3.0 0.0.0.127
access-list 1 permit 10.0.10.0 0.0.0.127
access-list 1 permit 10.0.20.0 0.0.0.127
access-list 1 permit 10.0.30.0 0.0.0.127
You also have a problem with your routing.
Both hosts which report destination unreachable are not on this router and the message implies they have no route for the destination networks.
You'd better give Alain a good rating for his help so far, this is another issue.
regards,
Leo
Uhh.... yes they are not on the NAT router but they are routed via ospf.
I always give high ratings. Lol.
This may very well be the case but you are not advertizing the 128-network.
regards,
Leo
This is what Alain has pointed out too and also you...
What do you mean by "advertising"? You mean like configure something that would enable them to advertise?
You mean like include the 128 network on my ospf configuration?
J
Your ospf process should include the following:
router ospf 1
network 128.10.10.0 0 0.0.0.255 area 0
regards,
Leo
thanks for taking your time in answering my question.
But the scenario that im trying to bring up here is that the 128.10.10.0 network is a public ip address and is not part of lets say my company's network system.
Or maybe the scenario that im trying to bring up is wrong.
regards
In that case, you need to have a default route to enable it's reachability.
This route must be redistributed by ospf.
regards,
Leo
Hi Leo,
Is this what you mean?
router ospf 1
ip classless
If not, then what configuration would you suggest?
And doesn't OSPF redistribute only classfull by default? How do you redistribute subnetted addresses?
router ospf 1
regards,
Leo
