PBR/Distribution List help
Andrew White
Level 2
Level 2
I have this simple lab to practise filtering traffic so R1 and R2 can't see each other in there routing tables:
I've tried 3 methods and only example 1 seems to work, what am I doing wrong?
Example 1 (Worked)
R3
router eigrp 200
redistribute eigrp 100
network 10.1.1.0 0.0.0.255
network 10.1.2.0 0.0.0.255
distribute-list 2 out FastEthernet0/0
distribute-list 1 out Serial0/0
no auto-summary
access-list 1 deny   10.1.2.0 0.0.0.255 log
access-list 1 permit any log
access-list 2 deny   10.1.1.0 0.0.0.255 log
access-list 2 permit any log
Example 2 (Didn't work the can ping each other)
R3
router eigrp 200
distribute-list 101 out FastEthernet0/0
distribute-list 100 out Serial0/0
no auto-summary
access-list 100 deny   ip 10.1.2.0 0.0.0.255 10.1.1.0 0.0.0.255 log
access-list 100 permit ip any any
access-list 101 deny   ip 10.1.1.0 0.0.0.255 10.1.2.0 0.0.0.255 log
access-list 101 permit ip any any
Example 3 (Didn't work they can ping each other)
R3
interface FastEthernet0/0
ip address 10.1.2.3 255.255.255.0
ip policy route-map pbr2
duplex auto
speed auto
interface Serial0/0
ip address 10.1.1.3 255.255.255.0
encapsulation ppp
ip policy route-map pbr1
clock rate 2000000
access-list 1 permit 10.1.2.0 0.0.0.255 log
access-list 2 permit 10.1.1.0 0.0.0.255 log
route-map pbr1 deny 10
match ip address 1
route-map pbr1 permit 20
route-map pbr2 deny 10
match ip address 2
route-map pbr2 permit 20
Maybe on example 2 I could use 1 route-map and redistribute into eigrp 200?
Hopefully someone with a fresh pair of eyes can help?
Richard Burts
In example 2 you coded the access lists like you would if you were  going to assign them with access-group on the physical interfaces where  you specify source address and destination address. But you are trying  to use the access list in a distribute list. In a distribute list you  are filtering the advertisement and advertisements do not have source  and destination addresses.
In  example 3 you are using route map deny logic which gets a bit tricky. I  suggest that you start with route maps which use permit in the route  map statement and deny in the access list logic. These are much more  easy to work with. After you get quite comfortable with route map logic  you can come back to the route map deny logic.
Rick
Rick
