pbr issue on 3750E switch
Madhan Kumar
Hi all,
I have implemented pbr on 3750E switch recently. The switch is having 10 vlans and configured with a default route also. After implementing the PBR I am getting some issues on intervlan routing even I am using deny statements. Is there anyway to change the priority I mean the routing table first and then the PBR?. Kindly help me
Rgds
R.MADHANKUMAR
Peter Paluch
Hello Madhan,
If using PBR on 3560/3750, there are a few caveats:
  • You need to use the IP Services IOS feature set.
  • Your SDM template must support PBR, which is currently sdm prefer routing or sdm prefer dual-ipv4-and-ipv6 routing
  • The deny statements in the route-map are not supported (i.e. it is not permitted to use route-map XXX deny).
  • If possible, avoid using deny statements even in the ACLs used by these route-maps. Packets that match a deny entry in the ACL are sent to the CPU, which could cause high CPU utilization
These information are based on the Configuration Guide for 3750 switches at:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750e_3560e/software/release/12.2_55_se/configuration/guide/swiprout.html
Try to correct your PBR configuration according to these guidelines, and if your issue still persists please include a detailed description of what is not working properly and also include the complete configuration of your PBR including route-maps and ACLs.
Best regards,
Peter
Hello Peter,
Thanks for your reply. I am using WS-C3750E-24TDE switch which is having universal IOS. Is this switch will support ip-services?.
Find my config here.
access-list 110 deny   ip host 192.168.11.11 10.68.100.0 0.0.0.255
access-list 110 deny   ip host 192.168.11.11 10.68.101.0 0.0.0.255
access-list 110 deny   ip host 192.168.11.11 10.68.102.0 0.0.0.255
access-list 110 deny   ip host 192.168.11.11 10.68.103.0 0.0.0.255
access-list 110 deny   ip host 192.168.11.11 10.68.104.0 0.0.0.255
access-list 110 deny   ip host 192.168.11.11 192.168.13.0 0.0.0.255
access-list 110 permit ip host 192.168.11.11 any
route-map pbr permit 10
match ip address 110
set ip next-hop 10.68.202.2
ip route 0.0.0.0 0.0.0.0 10.68.200.2
interface Vlan150
description Server Farm
ip address 192.168.11.1 255.255.255.0
ip policy route-map pbr
My server is 192.168.11.11 and it is reaching its next-hop 10.68.202.2. But from 192.168.11.0/24 subent I am not able to reach another vlans. This ios not supporting to enable default-next-hop.
Thanks & Regards
R.MADHANKUMAR
Try adding
route-map pbr permit 20
Bharat
Hi Bharath,
Thanks for your reply. I can add another PBR, but what might be the access-list?. Also if I am adding another PBR the cpu utilization will go high?
rgds
R.MADHANKUMAR
