PBR Problem on 45k with VSS active
Dear friends,
due to WCCP is not possible with VSS on that plattform I decided to user the PBR option.
But I didn't get a match on the LAN side. Does anyone have experience with PBR on that plattform and featureset?
I configured the same config in my LAB ASR1000v it works but in real on the 45k not!
any ideas whats going wrong on that plattform??
heres my config:
!!PBR ACL
ip access-list extended WAE_REDIRECT_LAN
 permit ip 10.2.0.0 0.0.255.255 10.1.0.0 0.0.255.255
ip access-list extended WAE_REDIRECT_WAN
 permit ip 10.1.0.0 0.0.255.255 10.2.0.0 0.0.255.255
!!route-map
route-map WAE-CORE-LAN permit
match ip address WAE_REDIRECT_LAN
set ip next-hop 10.79.4.4
route-map WAE-CORE-WAN permit
match ip address WAE_REDIRECT_WAN
!!Interface LAN
interface vlan 1
ip policy route-map WAAS-CORE-LAN
!!Interface WAN
interface vlan 105
ip policy route-map WAAS-CORE-WAN
FYI I run into that already a few month ago but get no solution, hopefully now anyone has an idea...
https://supportforums.cisco.com/discussion/12102506/pbr-problem-ws-c4500x-32
