site to site vpn issue...
IOS_support
 I am having issues with just the VPN to the main LAN regardless of the VLAN sub..... Can you help me? I've attached two things 1. new config 2. errors I'm encountering.
When I ping the public IPs; the VPN messages do not seem to error and I can ping. When I try to ping from the remote network to the local network (internal IPs) then I get these messages....
: Saved
ASA Version 9.1(2)
hostname SPTASA
domain-name SPT.LOCAL
enable password LCF3phzihasrhsIb encrypted
names
interface GigabitEthernet0/0
 speed 100
 duplex full
 nameif Outside
 security-level 0
 ip address E.E.E.E 255.255.255.248
interface GigabitEthernet0/1
 speed 100
 duplex full
 nameif Inside
 security-level 100
 ip address  B.B.B.B  255.255.255.0
interface GigabitEthernet0/1.20
 vlan 20
 nameif SPT_DC
 security-level 100
 ip address  C.C.C.C  255.255.255.0
interface GigabitEthernet0/2
 shutdown
 no nameif
 no security-level
 no ip address
ftp mode passive
clock timezone EST -5
clock summer-time EDT recurring
dns domain-lookup Inside
dns server-group DefaultDNS
 name-server  X.X.X.X
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object network SPT_Inside
 subnet B.B.B.B 255.255.255.0
 description SPT Inside Subnet
object network Inside
object network NETWORK_OBJ_B.B.B.B_24
object network AIM_Lan
 subnet  A.A.A.A  255.255.255.0
access-list AIM_s2s_VPN extended permit ip B.B.B.B 255.255.255.0 A.A.A.A  255.255.255.0
access-list AIM_s2s_VPN extended permit icmp  B.B.B.B  255.255.255.0 A.A.A.A  255.255.255.0
access-list AIM_s2s_VPN extended permit tcp  B.B.B.B  255.255.255.0 A.A.A.A  255.255.255.0
access-list AIM_s2s_VPN extended permit udp B.B.B.B  255.255.255.0 A.A.A.A  255.255.255.0
access-list AIM_s2s_VPN extended permit ip object AIM_Lan object Inside
pager lines 24
logging enable
logging asdm debugging
mtu Outside 1500
mtu Inside 1500
mtu DMZ 1500
mtu management 1500
mtu SPT_DC 1500
icmp unreachable rate-limit 1 burst-size 1
icmp permit any Outside
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
nat (Inside,Outside) source dynamic any interface
nat (Outside,Inside) source dynamic any interface
nat (SPT_DC,Outside) source dynamic any interface
nat (Outside,SPT_DC) source dynamic any interface
nat (Inside,Outside) source static Inside Inside destination static AIM_Lan AIM_Lan
route Outside 0.0.0.0 0.0.0.0 X.X.X.X  1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
http server enable
http B.B.B.B 255.255.255.0 Inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec ikev1 transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-SHA-TRANS esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-128-MD5-TRANS esp-aes esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-192-SHA-TRANS esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-192-MD5-TRANS esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-256-SHA-TRANS esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-256-MD5-TRANS esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-SHA-TRANS esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-3DES-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-3DES-MD5-TRANS esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA-TRANS esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-DES-MD5-TRANS esp-des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec ikev2 ipsec-proposal AES256
 protocol esp encryption aes-256
 protocol esp integrity sha-1 md5
crypto ipsec ikev2 ipsec-proposal AES192
 protocol esp encryption aes-192
crypto ipsec ikev2 ipsec-proposal 3DES
 protocol esp encryption 3des
crypto ipsec ikev2 ipsec-proposal DES
 protocol esp encryption des
crypto ipsec security-association pmtu-aging infinite
crypto map AIM_VPN_MAP 1 match address AIM_s2s_VPN
crypto map AIM_VPN_MAP 1 set peer D.D.D.D
crypto map AIM_VPN_MAP 1 set ikev1 transform-set ESP-AES-128-SHA
crypto map AIM_VPN_MAP interface Outside
crypto ca trustpool policy
crypto ikev1 enable Outside
crypto ikev1 policy 1
 authentication pre-share
 encryption 3des
 hash md5
 group 2
 lifetime 86400
telnet timeout 5
ssh timeout 5
ssh key-exchange group dh-group1-sha1
console timeout 0
dhcpd address B.B.B..2-B.B.B.154 Inside
dhcpd enable Inside
dhcpd address  B.B.B.2-B.B.B.154 SPT_DC
dhcpd enable SPT_DC
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
group-policy DfltGrpPolicy attributes
 vpn-tunnel-protocol ikev1 l2tp-ipsec ssl-clientless
tunnel-group D.D.D.D type ipsec-l2l
tunnel-group D.D.D.D  ipsec-attributes
 ikev1 pre-shared-key *****
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
 class inspection_default
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbSPT
  inspect tftp
  inspect ip-options
  inspect icmp
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:244ab793e694fe0eff06ef37cd8bd56c
: end
Errors I am getting:
3Jul 22 201413:46:58     Group = X.X.X.X, IP = X.X.X.X, Removing peer from correlator table failed, no match!
4Jul 22 201413:46:58     Group = X.X.X.X, Username = X.X.X.X, IP = X.X.X.X, Session disconnected. Session Type: LAN-to-LAN, Duration: 0h:00m:04s, Bytes xmt: 0, Bytes rcv: 0, Reason: crypto map policy not found
5Jul 22 201413:46:58     Group = X.X.X.X, IP = X.X.X.X, Session is being torn down. Reason: crypto map policy not found
3Jul 22 201413:46:58     Group = X.X.X.X, IP = X.X.X.X, QM FSM error (P2 struct &0x00007fff9fd2ed70, mess id 0xf088531b)!
Group = X.X.X.X, IP = X.X.X.X, Rejecting IPSec tunnel: no matching crypto map entry for remote proxy 0.0.0.0/0.0.0.0/0/0 local proxy 0.0.0.0/0.0.0.0/0/0 on interface Outside
7 Replies 7
Hi ,
 You need to correct following things ,
1) You crypto map acl should be same on both side . check the same with your peer location
2) You are doing PATing for any traffic moving out of outside interface , you should have nat 0 /nonat between your peer location .
Let me know if you need any assistance
Sandy
I have all of #1 correct.
Problem now is; tunnel is up remote network (A.A.A.A) can ping/access across the tunnel. This network doesn't have an ASA
But the ASA side (B.B.B.B.)  cannot ping/access the remote network (A.A.A.A)... When pinging it looks as if ASA is 'seeing' it, but I am also getting an error on the VPN/Trace Packet about configured rule issue.
Hi ,
I am suspecting Problem on Crypto MAP ACL .
Could you please join on below webex
https://meetings.webex.com/collabs/meetings/join?uuid=M5OB3OP4MVZ7W34FKYR2P36PFD-512H
Sandy
Says the meeting has ended... I setup a join.me  ~ 399-913-155
Could you please open it again ??
Sorry haveto do another one 620 849 543
        I have document attached which should support your requirement .
Sandy ,
