PBR question
codflanglers
I have an existing route map on my core that matches incoming traffic on a particular subnet and sets its next hop. That's all working as expected.
I now have a requirement to match another subnet and if it is destined for the subnet above, allow it to continue but if it is destined for anywhere else then set its next hop to the one above.
Maybe its been a long day, but is there a way I can do this? It doesn't have to use a route map, any method would do.
Hmm...
Let's say you have 192.168.1.0/24 and 192.168.2.0/24
You could create a route map and deny that route like:
access-list 100 permit ip 192.168.1.0 0.0.0.255 5.5.5.0 0.0.0.255
access-list 100 permit ip 192.168.2.0 0.0.0.255 any
access-list 101 permit ip 192.168.2.0 0.0.0.255 5.5.5.0 0.0.0.255
route-map Test deny 10
match ip address 101
route-map Test permit 20
match ip address 100
set ip next-hop 10.10.10.10
I think that's what you're looking for. If 192.168.2.0/24 tries to go to 5.5.5.0/24, it will route normally. All other traffic will route via the 20 sequence number.
HTH,
John
HTH, John *** Please rate all useful posts ***
John Blakley
So you want the policy to match on the new subnet, and if it's going to the destination in the prior sequence number, you want that to route normally? Or do you want it to go to the next hop that you specified in the other route map?
HTH,
John
If it is destined for the subnet above, route normally. If it is for any other destination then set a next hop.
Hmm...
HTH,
John
Awesome John, exactly what I need. Thanks
