PBR question
george_daly
Level 2
Level 2
Hi all,
Quick question relating to policy based routing. If I have a route-map which does:
Match ip address 10
access-list 10 has a source and dest IP, but there is no Set clause configured.
What will happen when a packet matches the access-list?
As I understand it the packet will be routed by the routing engine and the route-map is effectively doing nothing.
Can someone else confirm please?
bvsnarayana03
Level 10
Level 10
You are right. No effect. Pkts will be routed as in the routing table.
bvsnarayana03
Level 10
Level 10
Great stuff, thanks very much for the confirmation.
