Showing results forĀ
Search instead forĀ
Did you mean:Ā
PBR using dual ISP and single LAN subnet
samirshaikh52
Level 2
Level 2
I have 2 ISP connections on the Cisco router 29121 i.e. Leased Line and PPPoe and single LAN subnet
I want to use PBR.
I want to allow ip traffic destined for  1.1.1.1,2.2.2.2,3.3.3.3 ( Fictitious IP) to go through Lease Line
and all other traffic through PPPoe
Please help me to achieve this.
Thanks in advance.
22 Replies 22
You forgot the PBR policy under g0/2 and the PBR route-map.
Right now you have got 2 default routes of equal longest match and same AD so CEF will load-share per src-dst IP and will select  one outgoing interface for communication between 2 end points but you can't predict which one it will choose for a particular communication.If CEF is using one outgoing interface for your client  http connection to this destination then the NAT route-map must match the outgoing interface and if this not the case it won't work.
This is due to   a wrong nat route-map statement I proposed so do this:
route-map leased permit 10
no match ip address 101
match ip address 100
match interface GigabitEthernet0/0
route-map pppoe permit 10
match interface Dialer0
And don't forget the PBR if you want to force this traffic out a particuliar interface.
Alain
With same access list, how can I segregate the traffic
Thanks in advance.
The segregation is done with the PBR policy applied ingress on the inside nat interface and you forgot to add it to the config.
access-list 101 permit ip 192.168.5.0 0.0.0.255 host 1.1.1.1
access-list 101 permit ip 192.168.5.0 0.0.0.255 host 2.2.2.2
access-list 101 permit ip 192.168.5.0 0.0.0.255 host 3.3.3.3
route-map PBR permit 10
set ip next-hop 100.100.100.102
int g0/2
ip policy route-map PBR
Alain
WoW Great Thanks  cadet alain
It working as desired.
This is my current config. I just want you help for last thing
If leased line goes down, I want to direct the user to PPPoe
However, if PPPoe, the users should NOT BE directed to leased line
int gi0/0
description << Leased Line >>
ip address 100.100.100.101 255.255.255.252
ip nat outside
no shut
int gi0/2
description << LAN Subnet>>
ip address 10.1.50.1 ip nat inside
ip policy route-map lease
no shut
interface Dialer0
ip address negotiated
ip mtu 1492
ip nat outside
ip virtual-reassembly in max-reassemblies 512
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
dialer-group 1
ppp authentication pap chap callin
ppp chap hostname XXXXXXXXXXXXXXX
ppp chap password 0 9860
ppp pap sent-username XXXXXXXXXXXXXXX  password 0 9860
no cdp enable
interface GigabitEthernet0/1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no shut
ip nat outside
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
access-list 100 permit ip 10.1.50.0 0.0.0.255
route-map lease permit 10
match interface gi0/0
match interface dialer 0
ip nat inside source route-map lease interface gi0/0 overload
ip nat inside source route-map pppe interface dialer 0 overload
access-list 101 permit ip 10.10.1.50.0 0.0.0.255 host 1.1.1.1
acess-list 101 permit ip 10.1.50.0 0.0.0.255 host 4.2.2.2
ip route 0.0.0.0 0.0.0.0 dialer0
ip route 0.0.0.0 0.0.0.0 100.100.100.102
So you want the http traffic that is policy routed (on leased line)to take the other path if leased line is down but you don't want other traffic that is routed to adsl to take leased line if adsl goes down ?
if this is the case you can  do this:
ip route 8.8.8.8 255.255.255.255 100.100.100.102
ip sla 1
icmp-echo 8.8.8.8 source-interface g0/0
ip sla schedule 1 start now life forever
track 1 ip sla 1(  or track 1 rtr 1)
route-map PBR p 10
no set ip next-hop 100.100.100.102
set ip next-hop verifi-reachability 100.100.100.102 1 track 1
no ip route 0.0.0.0 0.0.0.0 100.100.100.102
Alain
Alain
Thanks. I have around 15 IP's I want to route them to leased line.
How would be possible in that case ?
I appreciate your big help.
BR
That's was easy
I just add the below and its working
set interface dialer 0
Thanks a lot for your support. I truly appreciate. It as BIG HELP
God bless you.
if you've got no connectivity through leased line ISP what you did won't work, you have to track an IP through this interface with the IP sla feature like I proposed.
Also if you leave both  default routes then traffic going through dialer interface will use leased line if dialer is down.
Anyway if you consider your case as resolved could you mark the thread as solved and rate helpful answers.
Alain
