PC Ping issue
surazb
Level 2
Level 2
I am preparing lab for home and i have exact below setup and config.
also issue is mentioned in attached snap
Can any one help me this behaviour please
Thanks in advanced 🙂
13 Replies 13
Georg Pauwen
try to set the default gateway of the PC to 172.16.10.2 (the first layer 3 interface, which is the Vlan 10 interface of the switch)...
That switch is layer 2 switch and IP on switch is only for management
But I did this solution as well still not able to ping Router from PC
if the switch is layer 2 only, set the default gateway on the PC to the IP address of the router (172.16.10.1), and on the switch, configure:
ip default-gateway 172.16.10.1
M02@rt37
Hello @surazb
Let PC Gateway as 172.16.10.1 ; IP hosted on L3 unit, so it is perfect.
You don't need ip default-gateway on Switch to have this ping successful.
Please do #show interface trunk on the Switch.
Ensure Giga 1/0/48 is dot1q interface and vlan 10 is allowed and forwarded on that port !
int Gi 1/0/48
switchport encapsulation dot1q
switchport mode trunk
switchport trunk allowed vlan 10
no shut
Best regards
M02@rt37
--> That switch is layer 2 switch and IP on switch is only for management
This means you definitely need the 'ip default-gateway'...
Hello @Georg Pauwen
Work on this issue first ; PC does not ping its gateway hosted on Router. After that, we gonna see how to manage that switch.
The command you mention is not needed to perform that specific ping.
Best regards
surazb
Level 2
Level 2
Switch port connecting to router is already trunk port with all VLANs forwarding, Also the gateway for PC is layer 2 which is configured on router
Correction !
 The gateway for PC is layer 3 which is configured on router
post the running configs (sh run) of both switch and the router...
surazb
Level 2
Level 2
Hi Guys,
Thanks a lot for you help and posts, Here is full config of Router and Switch in attachment
Thanks @surazb
Does Router ping the PC ?
Please shutdown PC firewall.
Best regards
Nope,
Cano not ping PC for router and vice-versa
Only switch can ping PC and Router as shown in attached config of switch
Ip access-list 100
Permit ip host <pc> host <router>
Then
Debug ip packets access list 100
Ping and Share output
MHM
