PC,router, switch, hub , which standards TIA or EIA
sarahr202
Level 5
Level 5
Hi every body!
I like to know the standards used by router, switch , personal computers and hubs. My book says there are two standards:
TIA
EIA
TIA has two standards:
T568A
T568B
thanks and enjoy your weekend!
Sarah
The only difference between T568A & T568B is that pairs 2 & 3 are swapped, see this link -
http://www.lashen.com/vendors/Leviton/Datacom/FAQ_TIA568.asp
So a straight thru cable is -
T568A both ends or T568B both ends
Pinouts are 1-1, 2-2, 3-3, 6-6
note that you can use either T568A or T568B for straight thru.
A cross-over cable is -
T568A on one end T568B on the other
pinouts are 1-3, 2-6, 3-1, 6-2
Jon
sarahr202
Level 5
Level 5
I found something, and thought it might be useful for someone looking for answers.
PC-NIC , router, wireless- access-point, use pin 1,2 to transmit and 3,6 to receive. This led me to believe they use T568A standard.
Switches and hubs use 1,2 to receive and 3,6 to transmit . Again this made me believe T568B is used here.
I assume by switches we mean layer 2 switches.
Sarah
Jon
Hi Jon!
Thanks for your reply.I understand the T568A and T568B standards.I understands when to use straight-through or cross-over cable.
What I really wanted to know is which standard is used in the device for cabling.
For example my book says PC 's NIC, routers, wireless access point use pins 1,2 to transmit and pins 3,6 to receive.
That means vendors use T568A .
On the other hand, hubs and switches use pins 1,2 to to receive and pins 3,6 to transmit. That means vendors use T568B standard in hubs and switches.
Had the same standard say T568A been used in all devices, we would have needed only cross-over cable to connect them together.
It seems T568 standards are favored over EIA standards by vendors.
thanks a lot!
