Peer link per VDC
abbasali5
Level 3
Level 3
Does VDC require separate Peer and Peer Keepalive Links per VDC?  If I were to configure 3 VDCs on a Nexus 7000 (i.e. that is Core/Aggregation/Server Farm, will it require three separate vPC Peer and Peer Keepalive link for each vDC between (2) Nexus 7000 switches?
Reza Sharifi
Yes, as far as I know, you can only connect VDCs together using physical cables as each VDC is like a separate switch.
Reza Sharifi
