Per slot switching capacity of a 4506
justin.allen
I have a SUP IV and some non E series line cards. How do I tell if I am exceeding the 6 gig per slot switching capacity of the 4506? Is there some command to use?
Justin
justin.allen
I think I might have answered my own question. Show buffer
jbrenesj
Level 3
Level 3
What I normally do without getting to the complicated commands is to check the interface for:
- Input and output drops
Since these line cards are oversuscribed 8:1 if you get beyond the capacity of the backplane connection (1 gig) per groups of 8 ports you'll normally see drops in all the ports of the affected group.
Also:
- sh int g3/1 counters all
You see Tx-Drops-Queue
- sh platform hardware int g3/1 statistics
You see some counter regarding txqueue-noavail or something like that when there are internal drops
