Per VLAN STP BPDU
I'm having an issue with SPT after adding more VLANS.  For now I'm trying to set it up so all of my VLANS just take the same route with the same root bridge.  The issue I'm having seems like it has a simple solution that I'm just overlooking.  Here's what I know for sure.
STP Port, Bridge, and Root settings are the exact same for all VLANS.
VLAN 1 Elects Root Bridge just fine-- all other VLANS just elect themselves as Root Bridge.
VLAN 1 Sends and Recieves BPDU's just fine.  All other/new vlans just send BPDU's but don't receive.
ALL VLANS allowed on all Trunk ports with no pruning.
ROOT BRIDGE for all VLANS -- S-SW1
S-SW1#show spanning-tree summary
Switch is in rapid-pvst mode
Root bridge for: VLAN0001, VLAN0201, VLAN0210, VLAN0220, VLAN0230, VLAN02
  VLAN0260, VLAN0285, VLAN0290, VLAN0299, VLAN0310, VLAN0330, VLAN0340
  VLAN0360
Extended system ID           is enabled
Portfast Default             is disabled
PortFast BPDU Guard Default  is enabled
Portfast BPDU Filter Default is disabled
Loopguard Default            is disabled
EtherChannel misconfig guard is enabled
UplinkFast                   is disabled
Stack port is StackPort1
BackboneFast                 is disabled
Configured Pathcost method used is short
Name                   Blocking Listening Learning Forwarding STP Active
VLAN0001                     0         0        0         28         28
VLAN0201                     0         0        0          6          6
VLAN0210                     0         0        0          6          6
VLAN0220                     0         0        0          6          6
VLAN0230                     0         0        0          7          7
VLAN0240                     0         0        0          6          6
VLAN0260                     0         0        0          6          6
VLAN0285                     0         0        0          6          6
VLAN0290                     0         0        0          6          6
VLAN0299                     0         0        0          6          6
VLAN0310                     0         0        0          6          6
VLAN0330                     0         0        0          6          6
VLAN0340                     0         0        0          6          6
VLAN0360                     0         0        0          6          6
14 vlans                     0         0        0        107        107
VLAN0001
  Spanning tree enabled protocol rstp
  Root ID    Priority    20481
             Address     001e.7a7e.0200
             This bridge is the root
             Hello Time   2 sec  Max Age 20 sec  Forward Delay 15 sec
  Bridge ID  Priority    20481  (priority 20480 sys-id-ext 1)
             Aging Time  600 sec
Interface           Role Sts Cost      Prio.Nbr Type
Gi1/0/1             Desg FWD 4         128.1    P2p Edge
Gi1/0/2             Desg FWD 4         128.2    P2p Edge
Fa1/0/17            Desg FWD 19        128.19   P2p Edge
Fa1/0/18            Desg FWD 19        128.20   P2p Edge
Gi1/0/3             Desg FWD 4         128.27   P2p
Gi1/0/4             Desg FWD 4         112.28   P2p
Fa1/0/29            Desg FWD 19        128.33   P2p Edge
Fa1/0/30            Desg FWD 19        128.34   P2p Edge
Fa1/0/31            Desg FWD 19        128.35   P2p Edge
Fa1/0/35            Desg FWD 19        128.39   P2p Edge
Fa1/0/36            Desg FWD 19        128.40   P2p Edge
Fa1/0/37            Desg FWD 19        128.41   P2p Edge
Fa1/0/38            Desg FWD 19        128.42   P2p Edge
Fa1/0/43            Desg FWD 19        128.47   P2p Edge
Fa1/0/44            Desg FWD 19        128.48   P2p Edge
Fa1/0/46            Desg FWD 19        128.50   P2p Edge
Gi2/0/1             Desg FWD 4         128.55   P2p Edge
Gi2/0/2             Desg FWD 4         128.56   P2p Edge
Fa2/0/1             Desg FWD 19        128.57   P2p Edge
Fa2/0/2             Desg FWD 19        128.58   P2p Edge
Fa2/0/3             Desg FWD 19        128.59   P2p Edge
Fa2/0/4             Desg FWD 19        128.60   P2p Edge
Fa2/0/5             Desg FWD 19        128.61   P2p Edge
Fa2/0/6             Desg FWD 19        128.62   P2p Edge
Fa2/0/7             Desg FWD 19        128.63   P2p Edge
Fa2/0/15            Desg FWD 19        128.71   P2p Edge
Fa2/0/16            Desg FWD 19        128.72   P2p Edge
Gi2/0/4             Desg FWD 4         112.82   P2p
VLAN0201
  Root ID    Priority    20681
  Bridge ID  Priority    20681  (priority 20480 sys-id-ext 201)
             Aging Time  600 sec
Gi1/0/3             Desg FWD 4         128.27   P2p Peer(STP)
VLAN0210
  Root ID    Priority    20690
  Bridge ID  Priority    20690  (priority 20480 sys-id-ext 210)
             Aging Time  600 sec
SW1
Root bridge for: VLAN0201, VLAN0210, VLAN0220, VLAN0230, VLAN0240, VLAN0260
  VLAN0285, VLAN0290, VLAN0299, VLAN0310, VLAN0330, VLAN0340, VLAN0360
VLAN0001                     1         0        0          7          8
VLAN0201                     0         0        0          4          4
VLAN0210                     0         0        0          4          4
VLAN0220                     0         0        0          4          4
VLAN0230                     0         0        0          8          8
VLAN0240                     0         0        0          4          4
VLAN0260                     0         0        0          4          4
VLAN0285                     0         0        0          4          4
VLAN0290                     0         0        0          4          4
VLAN0299                     0         0        0          4          4
VLAN0310                     0         0        0          4          4
VLAN0330                     0         0        0          4          4
VLAN0340                     0         0        0          4          4
VLAN0360                     0         0        0          4          4
14 vlans                     1         0        0         63         64
VLAN0001
             Cost        4
             Port        27 (GigabitEthernet1/0/3)
  Bridge ID  Priority    28673  (priority 28672 sys-id-ext 1)
             Address     001e.7ab0.8380
             Aging Time  300 sec
Fa1/0/1             Desg FWD 19        128.3    P2p Edge
Fa1/0/13            Desg FWD 19        128.15   P2p Edge
Fa1/0/19            Desg FWD 19        128.21   P2p Edge
Fa1/0/20            Desg FWD 19        128.22   P2p Edge
Gi1/0/3             Root FWD 4         112.27   P2p
Gi1/0/4             Altn BLK 4         112.28   P2p
VLAN0201
  Root ID    Priority    28873
  Bridge ID  Priority    28873  (priority 28672 sys-id-ext 201)
             Aging Time  300 sec
Gi1/0/3             Desg FWD 4         112.27   P2p
VLAN0210
  Root ID    Priority    28882
  Bridge ID  Priority    28882  (priority 28672 sys-id-ext 210)
             Aging Time  300 sec
VLAN0220
  Root ID    Priority    28892
  Bridge ID  Priority    28892  (priority 28672 sys-id-ext 220)
             Aging Time  300 sec
LOGGING
Log Buffer (4096 bytes):
AA AA 03 00000C 010B SSTP
264487: *Mar  1 09:45:36.262:     CFG P:0000 V:02 T:02 F:3C R:7154 001e.7ab0.8380 00000000
264488: *Mar  1 09:45:36.262:     B:7154 001e.7ab0.8380 70.1C A:0000 M:1400 H:0200 F:0F00
264489: *Mar  1 09:45:36.262:      T:0000 L:0002 D:0154
264490: *Mar  1 09:45:36.262: RSTP(340): sending BPDU out Fa1/0/46
264491: *Mar  1 09:45:36.262: STP SW: TX: 0100.0ccc.cccd<-001e.7ab0.83b2 type/len 0032
264492: *Mar  1 09:45:36.262:     encap SNAP linktype sstp vlan 340 len 64 on v340 Fa1/0/46
264493: *Mar  1 09:45:36.262:     AA AA 03 00000C 010B SSTP
264494: *Mar  1 09:45:36.262:     CFG P:0000 V:02 T:02 F:3C R:7154 001e.7ab0.8380 00000000
264495: *Mar  1 09:45:36.262:     B:7154 001e.7ab0.8380 80.32 A:0000 M:1400 H:0200 F:0F00
264496: *Mar  1 09:45:36.262:      T:0000 L:0002 D:0154
264497: *Mar  1 09:45:36.262: RSTP(360): sending BPDU out Fa1/0/1
4 6001001E7A9B7480 7052 0200 1400 0200 0F00
264595: *Mar  1 09:45:38.628: RSTP(1): Gi1/0/4 repeated msg
264596: *Mar  1 09:45:38.628: RSTP(1): Gi1/0/4 rcvd info remaining 6
264597: *Mar  1 09:45:38.645: RSTP(1): sending BPDU out Fa1/0/1
264598: *Mar  1 09:45:38.645: STP SW: TX: sstp copy: 0100.0ccc.cccd<-001e.7ab0.8383 type/len
264599: *Mar  1 09:45:38.645:     encap SNAP linktype sstp vlan 1 len 64 on v1 Fa1/0/1
264600: *Mar  1 09:45:38.645:     AA AA 03 00000C 010B SSTP
265023: *Mar  1 09:45:38.712:     CFG P:0000 V:02 T:02 F:3C R:7154 001e.7ab0.8380 00000000
265024: *Mar  1 09:45:38.712:     B:7154 001e.7ab0.8380 80.32 A:0000 M:1400 H:0200 F:0F00
265025: *Mar  1 09:45:38.712:      T:0000 L:0002 D:0154
265026: *Mar  1 09:45:38.712: RSTP(360): sending BPDU out Fa1/0/1
265027: *Mar  1 09:45:38.712: STP SW: TX: 0100.0ccc.cccd<-001e.7ab0.8383 type/len 0032
265028: *Mar  1 09:45:38.712:     encap SNAP linktype sstp vlan 360 len 64 on v360 Fa1/0/1
265029: *Mar  1 09:45:38.712:     AA AA 03 00000C 010B SSTP
8.201:     encap SNAP linktype sstp vlan 360 len 64 on v360 Gi1/0/3
269243: *Mar  1 09:45:58.201:     AA AA 03 00000C 010B SSTP
269244: *Mar  1 09:45:58.201:     CFG P:0000 V:02 T:02 F:3C R:7168 001e.7ab0.8380 00000000
269245: *Mar  1 09:45:58.201:     B:7168 001e.7ab0.8380 70.1B A:0000 M:1400 H:0200 F:0F00
269246: *Mar  1 09:45:58.201:      T:0000 L:0002 D:0168
269247: *Mar  1 09:45:58.201: RSTP(360): sending BPDU out Gi1/0/4
269248: *Mar  1 09:45:58.201: STP SW: TX: 0100.0ccc.cccd<-001e.7ab0.839c type/len 0032
269249: *Mar  1 09:45:58.201:     encap SNAP linktype sstp vlan 360 len 64 on v360 Gi1/0/4
269250: *Mar  1 09:45:58.201:     AA AA 03 00000C 010B SSTP
269251: *Mar  1 09:45:58.201:     CFG P:0000 V:02 T:02 F:3C R:7168 001e.7ab0.8380 00000000
269252: *Mar  1 09:45:58.201:     B:7168 001e.7ab0.8380 70.1C A:0000 M:1400 H:0200 F:0F00
269253: *Mar  1 09:45:58.201:      T:0000 L:0002 D:0168
269254: *Mar  1 09:45:58.201: RSTP(360): sending BPDU out Fa1/0/46
269255: *Mar  1 09:45:58.201: STP SW: TX: 0100.0ccc.cccd<-001e.7ab0.83b2 type/len 0032
269256: *Mar  1 09:45:58.201:     encap SNAP linktype sstp vlan 360 len 64 on v360 Fa1/0/46
269257: *Mar  1 09:45:58.201:     AA AA 03 00000C 010B SSTP
269258: *Mar  1 09:45:58.201:     CFG P:0000 V:02 T:02 F:3C R:7168 001e.7ab0.8380 00000000
269259: *Mar  1 09:45:58.201:     B:7168 001e.7ab0.8380 80.32 A:0000 M:1400 H:0200 F:0F00
269260: *Mar  1 09:45:58.201:      T:0000 L:0002 D:0168
269261: *Mar  1 09:45:58.562: STP SW: RX ISR: 0100.0ccc.cccd<-001e.7ab0.9d1c type/len 0032
269262: *Mar  1 09:45:58.562:     encap SNAP linktype sstp vlan 1 len 64 on v1 Gi1/0/4
 00000004
    B:6001 001e.7a9b.7480 70.52 A:0200 M:1400 H:0200 F:0F00
270775: *Mar  1 09:46:04.485:     B:7154 001e.7ab0.8380 70.1C A:0000 M:1400 H:0200 F:0F00
270776: *Mar  1 09:46:04.485:      T:0000 L:0002 D:0154
270777: *Mar  1 09:46:04.485: RSTP(340): sending BPDU out Fa1/0/46
270778: *Mar  1 09:46:04.485: STP SW: TX: 0100.0ccc.cccd<-001e.7ab0.83b2 type/len 0032
270779: *Mar  1 09:46:04.485:     encap SNAP linktype sstp vlan 340 len 64 on v340 Fa1/0/46
270780: *Mar  1 09:46:04.485:     AA AA 03 00000C 0
11 Replies 11
In order to select the root bridge a I recommend to use priorities,
Root Switch
spanning-tree vlan A,B,C,D,E... priority 4096 (the lowest value is 0)
Backup Root Switch
spanning-tree vlan A,B,C,D,E... priority 8192
* The lowest priority value will be selected as prefered, now each new VLAN must be added to the previous command lines.
It will resolve any problem with STP, also I recommend to use, spanning-tree guard root command line under the trunk interfaces facing to the access switches only (on the root and backup root switch)
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
NB: You can target all your VLANs with a statement like:
spanning-tree vlan 1-1004 priority #
Also BTW, some devices offer a symbolic for setting priority, but as it sometimes varies between platforms, suggest you use a numeric.
Thank you for the response.  I've tried lowering the root cost for all of the vlans on the root bridge but it doesn't work.  For VLAN1, the election process works fine.  But for all of the other VLANS they just elect themselves-- even though the root priorities are all set the same for all VLANS including VLAN1.
I think this is more of an issue with the BPDU's.  When I look at each the trunk ports for the VLAN they all show sending but not receiving BPDU's.  All VLANS are allowed on all trunks and VTP propagates just fine.
I feel like I'm overlooking something.
is the core switch the vtp server as well?
How many switches do you have, could you please provide the configs? also please include a show vtp status of each switch.
Here are the configs for the switches as well as the vtp status.  S-SW1 Should be root bridge for all VLANS.  H-SW1 should be secondary for all VLANS.
S-SW1#show vtp status
VTP Version capable             : 1 to 3
VTP version running             : 2
VTP Domain Name                 : CISCO
VTP Pruning Mode                : Enabled
VTP Traps Generation            : Disabled
Device ID                       : xxxx.xxxx.xxxx
Configuration last modified by S-SW1 at 3-1-93 20:28:33
Local updater ID is S-SW1 on interface Vl1 (lowest numbered VLAN interface found)
Feature VLAN:
VTP Operating Mode                : Server
Maximum VLANs supported locally   : 1005
Number of existing VLANs          : 19
Configuration Revision            : 49
MD5 digest                        : 0x9A 0xF1 0xD3 0x7C 0xDF 0x67 0x98 0xC2
                                    0x51 0xA5 0x17 0xA1 0xF4 0x4F 0xA6 0xEE
S-SW1#show run
Building configuration...
Current configuration : 10488 bytes
version 12.2
no service pad
service sequence-numbers
hostname S-SW1
boot-start-marker
boot-end-marker
no aaa new-model
clock timezone UTC -6
clock summer-time UTC recurring
switch 1 provision ws-c3750-48p
switch 2 provision ws-c3750-48p
system mtu routing 1500
no ip domain-lookup
spanning-tree mode rapid-pvst
spanning-tree vlan 1,201,210,220,230,240,260,285,290,299,310,330 priority 4096
spanning-tree vlan 340,360,400 priority 4096
spanning-tree vlan 200,250,270 priority 24576
vlan internal allocation policy ascending
!interface FastEthernet1/0/1
 spanning-tree portfast trunk
interface FastEthernet1/0/2
interface FastEthernet1/0/3
interface FastEthernet1/0/4
interface FastEthernet1/0/5
interface FastEthernet1/0/6
interface FastEthernet1/0/7
interface FastEthernet1/0/8
interface FastEthernet1/0/9
interface FastEthernet1/0/10
interface FastEthernet1/0/11
interface FastEthernet1/0/12
interface FastEthernet1/0/13
interface FastEthernet1/0/14
interface FastEthernet1/0/15
interface FastEthernet1/0/16
interface FastEthernet1/0/17
interface FastEthernet1/0/18
 switchport voice vlan 230
interface FastEthernet1/0/19
interface FastEthernet1/0/20
interface FastEthernet1/0/21
interface FastEthernet1/0/22
interface FastEthernet1/0/23
interface FastEthernet1/0/24
interface FastEthernet1/0/25
interface FastEthernet1/0/26
interface FastEthernet1/0/27
interface FastEthernet1/0/28
interface FastEthernet1/0/29
interface FastEthernet1/0/30
interface FastEthernet1/0/31
interface FastEthernet1/0/32
interface FastEthernet1/0/33
interface FastEthernet1/0/34
interface FastEthernet1/0/35
interface FastEthernet1/0/36
interface FastEthernet1/0/37
interface FastEthernet1/0/38
interface FastEthernet1/0/39
interface FastEthernet1/0/40
interface FastEthernet1/0/41
interface FastEthernet1/0/42
interface FastEthernet1/0/43
 switchport mode trunk
interface FastEthernet1/0/44
interface FastEthernet1/0/45
interface FastEthernet1/0/46
interface FastEthernet1/0/47
interface FastEthernet1/0/48
 switchport access vlan 2
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
 spanning-tree vlan 1 cost 4
interface GigabitEthernet1/0/4
 spanning-tree vlan 1,201,210,220,230,240,260,285,290,299,310 port-priority 112
 spanning-tree vlan 330,340 port-priority 112
interface FastEthernet2/0/1
interface FastEthernet2/0/2
interface FastEthernet2/0/3
interface FastEthernet2/0/4
interface FastEthernet2/0/5
interface FastEthernet2/0/6
interface FastEthernet2/0/7
interface FastEthernet2/0/8
interface FastEthernet2/0/9
interface FastEthernet2/0/10
interface FastEthernet2/0/11
interface FastEthernet2/0/12
interface FastEthernet2/0/13
interface FastEthernet2/0/14
interface FastEthernet2/0/15
interface FastEthernet2/0/16
interface FastEthernet2/0/17
interface FastEthernet2/0/18
interface FastEthernet2/0/19
interface FastEthernet2/0/20
interface FastEthernet2/0/21
interface FastEthernet2/0/22
interface FastEthernet2/0/23
interface FastEthernet2/0/24
interface FastEthernet2/0/25
interface FastEthernet2/0/26
interface FastEthernet2/0/27
interface FastEthernet2/0/28
interface FastEthernet2/0/29
interface FastEthernet2/0/30
interface FastEthernet2/0/31
interface FastEthernet2/0/32
interface FastEthernet2/0/33
interface FastEthernet2/0/34
interface FastEthernet2/0/35
interface FastEthernet2/0/36
interface FastEthernet2/0/37
interface FastEthernet2/0/38
interface FastEthernet2/0/39
interface FastEthernet2/0/40
interface FastEthernet2/0/41
interface FastEthernet2/0/42
interface FastEthernet2/0/43
interface FastEthernet2/0/44
interface FastEthernet2/0/45
interface FastEthernet2/0/46
interface FastEthernet2/0/47
interface FastEthernet2/0/48
interface GigabitEthernet2/0/1
interface GigabitEthernet2/0/2
interface GigabitEthernet2/0/3
interface GigabitEthernet2/0/4
interface Vlan1
 no ip route-cache
 no ip mroute-cache
interface Vlan210
 no ip address
 no ip route-cache
 no ip mroute-cache
interface Vlan220
 no ip address
 no ip route-cache
 no ip mroute-cache
interface Vlan230
 no ip address
 no ip route-cache
 no ip mroute-cache
interface Vlan285
 no ip address
 no ip route-cache
 no ip mroute-cache
interface Vlan290
 no ip address
 no ip route-cache
 no ip mroute-cache
interface Vlan299
ip classless
ip http server
ip http authentication local
ip http secure-server
ntp clock-period 36031988
mac address-table aging-time 600
end
H-SW1#show vtp status
Feature VLAN:
VTP Operating Mode                : Client
H-SW1#show run
Current configuration : 10849 bytes
version 12.2
no service pad
hostname H-SW1
boot-start-marker
boot-end-marker
no aaa new-model
no ip domain-lookup
errdisable recovery cause udld
errdisable recovery cause bpduguard
errdisable recovery cause security-violation
errdisable recovery cause channel-misconfig (STP)
errdisable recovery cause pagp-flap
errdisable recovery cause dtp-flap
errdisable recovery cause link-flap
errdisable recovery cause sfp-config-mismatch
errdisable recovery cause gbic-invalid
errdisable recovery cause l2ptguard
errdisable recovery cause psecure-violation
errdisable recovery cause port-mode-failure
errdisable recovery cause dhcp-rate-limit
errdisable recovery cause pppoe-ia-rate-limit
errdisable recovery cause mac-limit
errdisable recovery cause vmps
errdisable recovery cause storm-control
errdisable recovery cause inline-power
errdisable recovery cause arp-inspection
errdisable recovery cause loopback
errdisable recovery cause small-frame
errdisable recovery interval 30
spanning-tree vlan 1,201,210,220,230,240,260,285,290,299,310,330 priority 8192
spanning-tree vlan 340,360,400 priority 8192
 switchport access vlan 3
 switchport mode access
 spanning-tree vlan 330,340,360 port-priority 112
interface Vlan1
 no ip route-cache
 no ip mroute-cache
interface Vlan299
ip classless
ip http server
ntp clock-period 36029242
end
SW1#show vtp status
Feature VLAN:
SW1#show run
Current configuration : 6937 bytes
version 12.2
no service pad
hostname SW1
boot-start-marker
boot-end-marker
no aaa new-model
no ip domain-lookup
spanning-tree vlan 1,201,210,220,230,240,260,285,290,299,310,330 priority 12288
spanning-tree vlan 340,360,400 priority 12288
 switchport access vlan 200
 switchport access vlan 230
 spanning-tree vlan 1 port-priority 192
interface Vlan1
interface Vlan299
ip classless
ip http server
end
You are in a big trouble trouble there. Redundant topology and only VLAN1 has blocking port.
To begin with something remove portfast from all trunk ports that are not connected to end devices. Configurations are full of inconsistencies. If ports on topology are properly marked:
!S-SW1
 no spanning-tree portfast trunk
H-SW1
SW1
Can you paste result from
sh interface trunk
from all switches?
Thank you for the response.  I'm attaching the requested information.  The trunk ports with fastport enabled are for Access Points with Multiple Vlans.  The Bridge Trunk Ports are the gigabit ports I've indicated below.
S-SW1#sh interface trunk
Port        Mode             Encapsulation  Status        Native vlan
Fa1/0/43    on               802.1q         trunking      1 (AP)
Fa1/0/44    on               802.1q         trunking      1 (AP)
Fa1/0/46    on               802.1q         trunking      1 (AP)
Gi1/0/3     on               802.1q         trunking      1 (Router)
Gi1/0/4     on               802.1q         trunking      1 (Bridge)
Gi2/0/4     on               802.1q         trunking      1 (Bridge)
Port        Vlans allowed on trunk
Fa1/0/43    1-4094
Fa1/0/44    1-4094
Fa1/0/46    1-4094
Gi1/0/3     1-4094
Gi1/0/4     1-4094
Gi2/0/4     1-4094
Port        Vlans allowed and active in management domain
Fa1/0/43    1,201,210,220,230,240,260,285,290,299,310,330,340,360,400
Fa1/0/44    1,201,210,220,230,240,260,285,290,299,310,330,340,360,400
Fa1/0/46    1,201,210,220,230,240,260,285,290,299,310,330,340,360,400
Gi1/0/3     1,201,210,220,230,240,260,285,290,299,310,330,340,360,400
Gi1/0/4     1,201,210,220,230,240,260,285,290,299,310,330,340,360,400
Gi2/0/4     1,201,210,220,230,240,260,285,290,299,310,330,340,360,400
Port        Vlans in spanning tree forwarding state and not pruned
Gi1/0/3     1,220,230,260,285,299
H-SW1#sh int trunk
Fa1/0/43    1-4094
Fa1/0/44    1-4094
Fa1/0/46    1-4094
Gi1/0/3     1-4094
Gi1/0/4     1-4094
Gi2/0/4     1-4094
Gi1/0/3     1,220,285,330,340,360
H-SW1#
SW1#show int trunk
Fa1/0/1     on               802.1q         trunking      1 (Management Terminal)
Gi1/0/3     on               802.1q         trunking      1 (Bridge)
Fa1/0/1     1-4094
Fa1/0/46    1-4094
Gi1/0/3     1-4094
Gi1/0/4     1-4094
Fa1/0/1     1,201,210,220,230,240,260,285,290,299,310,330,340,360,400
Gi1/0/4     201,210,220,230,240,260,285,290,299,310,330,340,360,400
SW1#
The only explanations that only VLAN1 is finding loop free topology that I can think of:
- BPDUs are filtered (not present in configurations)
- There are devices between switches that are configured only with VLAN1 (or filtering BPDUs)
Currently, according to output from STP and the fact that the same VLANs are allowed on trunks between switches and only VLAN1 has blocking port you have network loops in all VLANs except VLAN1.  In that case you should at least shut down one interface to break loop and enable that port only when you are troubleshooting issue until issue is resolved. Or you can manually prune VLANs except VLAN1 on one interface (VLAN1 is blocking port on one of switches so there is no network loop there). One of ports Gi1/0/3 or Gi1/0/4 on SW1 looks like good candidate to be shutdown.
Thanks for the response.  I'm going to do that for now.  I'm not sure if this would have anything to do with it, but the routers having 4 port gb switching modules installed which attached to the main network.  They all find the correct root bridge, so I'm curious if there's a protocol misconfiguration on the switches.  The switchports on the routers all show they're using ieee stp protocol while the switches show they're using rstp protocol.  Should I just disable STP on the routers all together?
I did some further troubleshooting.
I'm not receiving BPDU's for any VLANS other than 1.
I am receiving multicast packets without errors.
I changed the trunks to ISL encapsulation and STP works perfectly fine with bpdus being received but all my other access point trunks and router trunks are all still dot1q.
Below is some of the troubleshooting I did for dot1q trunks.  For now, I'll just leave them as ISL trunks though I prefer dot1q.
SW1#show spanning-tree interface g1/0/4 detail
 Port 28 (GigabitEthernet1/0/4) of VLAN0001 is alternate blocking
   Port path cost 4, Port priority 112, Port Identifier 112.28.
   Designated root has priority 4097, address 001e.7a7e.0200
   Designated bridge has priority 8193, address 001e.7a9b.7480
   Designated port id is 112.82, designated path cost 4
   Timers: message age 16, forward delay 0, hold 0
   Number of transitions to forwarding state: 6
   Link type is point-to-point by default
   BPDU: sent 131, received 1402
 Port 28 (GigabitEthernet1/0/4) of VLAN0201 is designated forwarding
   Designated root has priority 32969, address 001e.7ab0.8380
   Designated bridge has priority 32969, address 001e.7ab0.8380
   Designated port id is 112.28, designated path cost 0
   Timers: message age 0, forward delay 0, hold 0
   Number of transitions to forwarding state: 1
   BPDU: sent 1481, received 0
SW1#show interface g1/0/4 counters
Port            InOctets    InUcastPkts    InMcastPkts    InBcastPkts
Gi1/0/4         13331767           5079          61695          66136
Port           OutOctets   OutUcastPkts   OutMcastPkts   OutBcastPkts
Gi1/0/4         35208651           5772         269852          93282
Gi1/0/4         13337536           5079          61720          66159
Gi1/0/4         35215909           5772         269924          93287
SW1#show interface g1/0/4 counters errors
Port        Align-Err     FCS-Err    Xmit-Err     Rcv-Err  UnderSize  OutDiscards
Gi1/0/4             0           0           0           0          0            0
Port      Single-Col  Multi-Col   Late-Col  Excess-Col  Carri-Sen      Runts     G
Gi1/0/4            0          0          0           0          0          0
SW1#test spanning-tree process-stats
------------------TX STATS------------------
 transmission rate/sec     = 32
 paks transmitted          = 1234855
 paks transmitted (opt)    = 45
 opt chunk alloc failures  = 255892
 max opt chunk allocated   = 6
------------------RX STATS------------------
 receive rate/sec          = 1
 paks received at stp isr  = 76246
 paks queued at stp isr    = 76246
 paks dropped at stp isr   = 0
 drop rate/sec             = 0
 paks dequeued at stp proc = 76246
 paks waiting in queue     = 0
 queue depth               = 5(max) 12288(total)
--------------PROCESSING STATS---------------
 queue wait time (in ms)   = 1(avg) 227(max)
 processing time (in ms)   = 0(avg) 9(max)
 proc switch count         = 100
 add vlan ports            = 26
 time since last clearing  = 38406 sec
SW1#test spanning-tree get configuration vlan
Spanning Tree Bridge configuration
SW1#test spanning-tree get configuration mst
% Incomplete command.
SW1#test spanning-tree get configuration mst ?
  <0-4094>  MST instance id
SW1#test spanning-tree get configuration mst 1
no Spanning Tree Bridge config present for mst 1
SW1#test spanning-tree get configuration mst 0
no Spanning Tree Bridge config present for mst 0
S
SW1#test spanning-tree switch-count ?
  <20-10000>  STP pak switch count
  default     default STP pak switch count
SW1#test spanning-tree switch-count default
SW1#
Just wanted to give an update.  The issue actually was with the Ubiquiti wireless bridges we were using.  They are supposed to be completely transparent but I guess that SSTP's were being dropped with the current firmware.  They had a newer release candidate firmware that fixed it.
