Permission denied in switch prompt
mahmoodmkl
Level 7
Level 7
Hi Guys,
I m getting permission denied message in switch prompt on 2950 when issuing dir flash: command.
Mahmood
lgijssel
Level 9
Level 9
This is what i get:
switch>sh priv
Current privilege level is 1
switch>dir flash:
% Invalid input detected at '^' marker.
switch>sh flash:
Directory of flash:/
2 -rwx 269 Jan 01 1970 01:01:28 +01:00 env_vars
3 -rwx 2967 Sep 12 2007 11:43:50 +02:00 config.text
4 -rwx 25 Sep 12 2007 11:43:50 +02:00 private-config.text
5 -rwx 109 Mar 01 1993 01:01:14 +01:00 info
6 -rwx 3121383 Mar 01 1993 01:02:39 +01:00 c2950-i6q4l2-mz.121-22.EA9.bin
7 drwx 4096 Mar 01 1993 01:03:13 +01:00 html
413 -rwx 109 Mar 01 1993 01:03:48 +01:00 info.ver
414 -rwx 1048 Sep 12 2007 11:43:50 +02:00 multiple-fs
7741440 bytes total (2817024 bytes free)
switch>
When you are really getting "Permission denied", it is likely that the switch has its default privilege levels modified in the configuration. In that case, either default the switch or consult it's administrator.
regards,
Leo
I m getting this message in switch: when trying to recover the password.
When i type dir flash: i m getting this message.
Mahmood
Mahmood,
It looks like your switch is missing an image file required for the bootup process.
Please take a look at the following link for procedures describing how to recover from a
missing image:
http://www.cisco.com/warp/public/473/192.html
~JG
