Permissions between 2 domains
slayerhawk
Hi all, I have two domains connected via an 1811 router. I have one FA0 set to 172.17.1.145/16 and FA1 set to 192.168.250.200/24.
I have two NT4.0 domain controllers on the 172.17.x.x subnet.
I am trying to add file permissions to objects that are in the 172.17.x.x subnet. I am attempting to add permissions for users that exist in the 192.168.250.x subnet to files and folders in the 172.17.x.x subnet. I have two domain controllers 172.17.2.80 and 172.17.2.100. I cannot add permissions to 192.168.250.x users for resources in 172.17.x.x subnet.
In addition, I want to stop traffic originating from 172.17.x.x getting to 192.168.250.x unless it is from the two domain controllers 172.17.2.80 and 172.17.2.100.
Here is the access list i am using.
interface FastEthernet0
ip address 172.17.1.145 255.255.0.0
ip access-group 199 in
ip helper-address 192.168.250.13
ip helper-address 192.168.250.14
ip directed-broadcast
ip nat outside
ip virtual-reassembly
no ip route-cache cef
no ip route-cache
no ip mroute-cache
speed auto
half-duplex
interface FastEthernet1
ip address 192.168.250.200 255.255.255.0
ip helper-address 172.17.2.60
ip helper-address 172.17.2.30
ip helper-address 172.17.2.255
ip helper-address 172.17.255.255
ip helper-address 172.16.255.255
ip nat inside
no ip route-cache
no ip mroute-cache
duplex auto
speed auto
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface FastEthernet9
interface Vlan1
no ip address
interface Async1
no ip address
encapsulation slip
interface Dialer1
no ip address
no cdp enable
ip forward-protocol udp netbios-ss
ip forward-protocol udp 42508
ip route 0.0.0.0 0.0.0.0 192.168.250.1
ip route 172.16.0.0 255.255.0.0 172.17.1.1
ip route 172.17.0.0 255.255.0.0 172.17.1.1
no ip http server
no ip http secure-server
ip nat inside source route-map nonat interface FastEthernet0 overload
logging 172.17.1.31
access-list 3 permit any
access-list 110 deny ip 192.168.250.0 0.0.0.255 172.16.0.0 0.0.255.255
access-list 110 deny ip 192.168.250.0 0.0.0.255 172.17.0.0 0.0.255.255
access-list 110 permit ip 192.168.250.0 0.0.0.255 any
access-list 120 permit ip 192.168.250.0 0.0.0.255 172.16.0.0 0.0.255.255
access-list 120 permit ip 192.168.250.0 0.0.0.255 172.17.0.0 0.0.255.255
access-list 121 permit ip 192.168.250.0 0.0.0.255 172.16.0.0 0.0.255.255
access-list 121 permit ip 192.168.250.0 0.0.0.255 172.17.0.0 0.0.255.255
access-list 189 permit icmp any any echo-reply
access-list 189 permit tcp any any established
access-list 189 deny ip 172.16.0.0 0.0.255.255 any
access-list 189 deny ip 172.17.0.0 0.0.255.255 any
access-list 189 permit ip any any
access-list 198 permit ip 172.16.0.0 0.0.255.255 192.168.250.0 0.0.0.255
access-list 198 permit ip 172.17.0.0 0.0.255.255 192.168.250.0 0.0.0.255
access-list 199 permit ip host 172.17.2.80 any
access-list 199 permit ip host 172.17.2.100 any
access-list 199 permit udp any eq netbios-ns any
access-list 199 permit udp any eq netbios-dgm any
access-list 199 permit udp any eq netbios-ss any
access-list 199 permit tcp any any established
access-list 199 permit icmp any any echo-reply
access-list 199 deny ip 172.17.0.0 0.0.255.255 192.168.250.0 0.0.0.255
access-list 199 deny ip 172.16.0.0 0.0.255.255 192.168.250.0 0.0.0.255
access-list 199 permit ip any any
priority-list 1 protocol ip high
Do I need to pint my helper addresses to be the same?
aghaznavi
Level 5
Level 5
Verify your ACL once again.
