Perticular Source to Destination bandwidth allocation?
c82_patel
I am having 1 Mbps Link.But in my scenerio perticular one source to one destination consuming 80% of total bandwidth.
I need to allocate 200 Kbps for this source to destination. Or can we bound bandwidth restriction on specific Services,Port,Source and destination.
aijaz802
HI,
You can use the QOS on the router.
1. Create an extended acl with source/dest n protocol
access-list 101 permit tcp sourceip/mask destip/mask eq www/any port
2. apply it on the interface with the rate-limit command
int se x/x
rate-limit input access-group 101 200000 24000 32000 conform-action transmit exceed-action drop
Please go thru the following link for more info.
http://www.cisco.com/en/US/docs/ios/12_0/qos/command/reference/qrcmdr.html
Pls. rate if it helps..
BR
*aijaz*
aijaz802
HI,
int se x/x
BR
*aijaz*
