Physical stacking question
cnyengineer
Community Member
Quick question.
I just installed two MS350s at one of my locations and stacked them together. The stack seems to be working fine and the dashboard didn't complain about anything however I'm only using one stack cable going from port 1 on switch 1 to port 1 on switch 2. Traffic is shown as going across that stack link too.
Is this correct? We do have another location where only two MS250s are stacked and I see two stacking cables between them.
7 Replies 7
Frank Osberg
Level 3
Level 3
Normal recommendation is that you do a cross stack, meaning using 2 stack cables, but you can use it with only 1, but you will miss your redundancy here then.
Frank Osberg | Domain Architect @ Solar A/S
LinkedIn - Twitter
Found this helpful? Give me some Kudos! Much Thanks
aleabrahao
Meraki Community All-Star
The ideal would be to have two cables for the Stack for high availability reasons. But as it is, it will not prevent it from functioning correctly.
I am not a Cisco employee. My suggestions are based on documentation of Cisco, best practices and day-to-day experience.
Please, if this post was useful, leave your kudos and mark it as solved.
cnyengineer
Community Member
Okay, thanks for the clarification.
One other question on this topic: Can I have an uplink to the firewall on both of the stack members? In the physical stacking guide it mentions just having a single uplink.
aleabrahao
If your firewall supports LACP you can definitely do this. But if it is a Meraki firewall you have to enable STP since the MX does not support LACP.
https://documentation.meraki.com/MX/Networks_and_Routing/MX_Layer_2_Functionality#LACP_.26_Link_Aggregation
Agree, but most firewalls can do this. 😉
LinkedIn - Twitter
Brash
To add to the other answers in this thread, using 2 cables to stack in a 'ring' topology isn't just recommended, it's the supported topology as per the stacking guide.
https://documentation.meraki.com/MS/Stacking/Switch_Stacks#Configuring_a_Physical_Switch_Stack
joey.debra
It will work as it is now but it is in fact a failure scenario. You should invest that little 100-ish$ for the second cable and just connect the full ring.
