PIM DENSE MODE in Switch 3560
vipinyadav84
Sir,
I want enable PIM DM in my Cisco switch 3560.
The error i get while configuring is "input not detected".Please Reply..
Jon Marshall
Could you post output of "sh ver" and also post the configuration commands you are using to configure pim.
Jon
Cisco IOS Software, C3560 Software (C3560-IPBASE-M), Version 12.2(25)SEE2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Fri 28-Jul-06 07:19 by yenanh
Image text-base: 0x00003000, data-base: 0x00EB0F14
ROM: Bootstrap program is C3560 boot loader
BOOTLDR: C3560 Boot Loader (C3560-HBOOT-M) Version 12.2(25r)SEC, RELEASE SOFTWARE (fc4)
GoldstoneTechnologies uptime is 2 weeks, 1 day, 3 hours, 8 minutes
System image file is "flash:c3560-ipbase-mz.122-25.SEE2/c3560-ipbase-mz.122-25.SEE2.bin"
cisco WS-C3560-24TS (PowerPC405) processor (revision D0) with 118784K/12280K bytes of memory.
Processor board ID CAT1108ZJ1N
Last reset from power-on
1 Virtual Ethernet interface
24 FastEthernet interfaces
2 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:1A:E3:EF:41:00
Motherboard assembly number : 73-9897-06
Power supply part number : 341-0097-02
Motherboard serial number : CAT110850YV
Power supply serial number : AZS110410N6
Model revision number : D0
Motherboard revision number : A0
Model number : WS-C3560-24TS-S
System serial number : CAT1108ZJ1N
Top Assembly Part Number : 800-26160-02
Top Assembly Revision Number : C0
Version ID : V02
CLEI Code Number : COMMG00ARB
Hardware Board Revision Number : 0x01
Switch Ports Model SW Version SW Image
* 1 26 WS-C3560-24TS 12.2(25)SEE2 C3560-IPBASE-M
Configuration register is 0xF
interface vlan 1
ip address 192.168.3.10 255.255.255.0
ip pim dense-mode
You have the IP Base image which does not support multicast routing.
You need the IP Services image to do this.
Jon
Hi Vipim,
As Jon stated you need ip services image.
So download image "c3560-ipservices-mz.122-25.SEE2.bin "
Also you can use Feature Navigator for finding features in particular images and platforms
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Ankur
*Pls rate all helpfull post
