PIM neighbors flapping
AmitLohumi
We had a recent change on our network wherein we changed over to MHSRP from plain HSRP and distributed vlans on the Core-Switches on odd-even basis. Ever since the change Multicast receivers on the odd VLANs are experiencing breakages in multicast stream. The following PIM messages are repeatedly logged on the Switches :
Jan 15 12:17:14 IST: %PIM-5-NBRCHG: neighbor 10.216.69.3 DOWN on interface Vlan69 DR
Jan 15 13:44:41 IST: %PIM-5-NBRCHG: neighbor 10.216.63.3 DOWN on interface Vlan63 DR
Jan 15 13:44:41 IST: %PIM-5-DRCHG: DR change from neighbor 10.216.63.3 to 10.216.63.2 on interface Vlan63
Jan 15 13:44:46 IST: %PIM-5-NBRCHG: neighbor 10.216.65.3 DOWN on interface Vlan65 DR
Jan 15 13:44:46 IST: %PIM-5-DRCHG: DR change from neighbor 10.216.65.3 to 10.216.65.2 on interface Vlan65
Jan 15 13:44:48 IST: %PIM-5-NBRCHG: neighbor 10.216.52.3 DOWN on interface Vlan52 DR
Jan 15 13:44:48 IST: %PIM-5-DRCHG: DR change from neighbor 10.216.52.3 to 10.216.52.2 on interface Vlan52
Jan 15 13:45:02 IST: %PIM-5-NBRCHG: neighbor 10.216.64.3 DOWN on interface Vlan64 DR
Jan 15 13:45:02 IST: %PIM-5-DRCHG: DR change from neighbor 10.216.64.3 to 10.216.64.2 on interface Vlan64
Jan 15 13:45:02 IST: %PIM-5-NBRCHG: neighbor 10.216.72.3 DOWN on interface Vlan72 DR
Jan 15 13:45:02 IST: %PIM-5-DRCHG: DR change from neighbor 10.216.72.3 to 10.216.72.2 on interface Vlan72
Jan 15 13:45:05 IST: %PIM-5-NBRCHG: neighbor 10.216.53.3 DOWN on interface Vlan53 DR
Jan 15 13:45:05 IST: %PIM-5-DRCHG: DR change from neighbor 10.216.53.3 to 10.216.53.2 on interface Vlan53
Jan 15 13:55:58 IST: %PIM-5-DRCHG: DR change from neighbor 0.0.0.0 to 10.216.81.2 on interface Vlan81 Jan 15 13:44:41 IST: %PIM-5-NBRCHG: neighbor 10.216.63.3 DOWN on interface Vlan63 DR
It apears that PIM neighborships are not stable. Anyone has a clue on how to proceed with further troubleshooting on this ? The multicast application being used is one for trading. Its called Odin.
Amit
AJAZ NAWAZ
Level 5
Level 5
Hi Amit
Did you find a fix for this please?
thanks
pramz087032
Hi Amit,
Check for any flaps observed in routing protocols. This might be the cause for PIM neighbor flapping.
John Blakley
I agree with Pramod. PIM depends on the routing table being converged first, and if there are any changes in that, you'll notice it in pim as well.
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
