Ping between VLAN's
Marco_Cordero
Hi, I have this issue where I'm trying to create multiple networks with a couple of routers on a stick. I've succesfully pinged between one side to the same side but not from one to another. Here's an image of the logical diagram.
S0 has Vlan 10, S1 has Vlan 20 and so on. I can ping from PC0 to PC1 but not from PC0 to PC2.
I already configured subinterfaces on the router but I don't know what to configure on the central portion of the diagram.
luis_cordova
Hi @Marco_Cordero
Try this
Router0
R(config)#ip route 192.168.0.96 255.255.255.224 se0/x/x <— must be the serial interface in use of this router
R(config)#ip route 192.168.0.128 255.255.255.224 se0/x/x <— must be the serial interface in use of this router
Router1
R(config)#ip route 192.168.0.0 255.255.255.224 se0/x/x <— must be the serial interface in use of this router
R(config)#ip route 192.168.0.32 255.255.255.224 se0/x/x <— must be the serial interface in use of this router
7 Replies 7
post the zipped Packet Tracer project file...
Here it is
luis_cordova
Hi @Marco_Cordero
Try this
Router0
Router1
Well, that seem to work but I'm trying to configure subinterfaces and VLAN's, do I really need to define routes? I thought that between VLAN's one didn't need that, what's the explanation behind this?
Hi @Marco_Cordero
Routers divide broadcast domains, so if you have more than one router, you must route, either with static routes or routing protocols.
I thought so, thnx.
