Ping not responding
Ranjan Singh
Level 3
Level 3
I have cisco WS-C2960G-24TC-L with IOS c2960-lanbasek9-mz.150-2.SE6.bin
I am facing Ping not responding issue once I applied  NO IP HOST-ROUTING command.
Switch stopped pinging after applying this command. Please help.
devils_advocate
Level 11
Level 11
It is not a command I have seen before and I can't find a huge amount of information online about it.
Out of interest, why did you run this command?
I would never do a negate to a command which I was not 100% sure what it was for.
Hi Devils,
We are using this to disable host based routing.
I have multiple switches with same model and IOS running in my environment and i have used no ip host-routing but i haven't faced such issue before.please suggest
