ping problem
bkoum
Level 3
Level 3
hello
there are two 3550 connected using the fa 0/1 port and althought i can ping one another throught interface vlan1 , i cant ping to the interface fa0/1 from the vlan1 using extended ping. also i cant see any routing update in the routing table.
can anybody help ?
thanks
can u ping 100.100.100.1 from that host? whts default gateway configured on ur host?it should be 192.168.12.5
6 Replies 6
Edison Ortiz
Can you modify your RIP environment with Version 2 and disable auto-summary ?
For instance:
router rip
version 2
network 100.0.0.0
network 192.168.12.0
network 192.168.30.0
network 195.167.73.0
no auto-summary
on both routers
hello
i tested it but still nothing
Mpoumpoulinas42#ping
Protocol [ip]:
Target IP address: 192.168.12.25
Repeat count [5]:
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface: 100.100.100.1
Type of service [0]:
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Sweep range of sizes [n]:
Sending 5, 100-byte ICMP Echos to 192.168.12.25, timeout is 2 seconds:
Success rate is 0 percent (0/
i was thinking it would be easy to connect two 3550 with routing but i can understand why its so complecate.
hello,
as per ur config,ip address 192.168.12.25 belongs to wht? host connected fa0/3 of Mpoumpoulinas42? or anything else??
if host then whts configured dg?
first try normal ping whether it is pinging.
let us know the results.
rgrds,
yes , host 192.168.12.25 belongs into a switch connected at fa0/3 ....normal ping respond 5/5.
It should be but it is nt 🙂 this maching connected to the internet via another adsl router ...thanks
