ping spike issues between mikrotik CCR
blackmetal
i have a Mikrotik CCR 1009-7g-1s-1s+ with s+85dlc03d and connect it to a cisco 3750e-48td-s x2-10gb-sr so router and switch connected by a sfp+ cable but i have ping spike issue and this is the result (this is ping test from CCR -> 3750e over SFP+ port:
    sent=700 received=700 packet-loss=0% min-rtt=0ms avg-rtt=1ms max-rtt=28ms
  SEQ HOST                                     SIZE TTL TIME  STATUS
  700 192.168.1.1                                56 255 0ms
  701 192.168.1.1                                56 255 1ms
  702 192.168.1.1                                56 255 0ms
  703 192.168.1.1                                56 255 1ms
  704 192.168.1.1                                56 255 4ms
  705 192.168.1.1                                56 255 0ms
  706 192.168.1.1                                56 255 0ms
  707 192.168.1.1                                56 255 5ms
  708 192.168.1.1                                56 255 0ms
  709 192.168.1.1                                56 255 0ms
  710 192.168.1.1                                56 255 0ms
  711 192.168.1.1                                56 255 0ms
  712 192.168.1.1                                56 255 0ms
  713 192.168.1.1                                56 255 0ms
  714 192.168.1.1                                56 255 0ms
  715 192.168.1.1                                56 255 0ms
  716 192.168.1.1                                56 255 0ms
  717 192.168.1.1                                56 255 0ms
  718 192.168.1.1                                56 255 5ms
  719 192.168.1.1                                56 255 0ms
    sent=720 received=720 packet-loss=0% min-rtt=0ms avg-rtt=1ms max-rtt=28ms
  720 192.168.1.1                                56 255 0ms
  721 192.168.1.1                                56 255 0ms
  722 192.168.1.1                                56 255 0ms
  723 192.168.1.1                                56 255 0ms
  724 192.168.1.1                                56 255 0ms
  725 192.168.1.1                                56 255 0ms
  726 192.168.1.1                                56 255 1ms
  727 192.168.1.1                                56 255 4ms
  728 192.168.1.1                                56 255 4ms
  729 192.168.1.1                                56 255 0ms
  730 192.168.1.1                                56 255 0ms
  731 192.168.1.1                                56 255 0ms
  732 192.168.1.1                                56 255 0ms
  733 192.168.1.1                                56 255 0ms
  734 192.168.1.1                                56 255 0ms
  735 192.168.1.1                                56 255 0ms
  736 192.168.1.1                                56 255 0ms
  737 192.168.1.1                                56 255 0ms
  738 192.168.1.1                                56 255 0ms
  739 192.168.1.1                                56 255 4ms
    sent=740 received=740 packet-loss=0% min-rtt=0ms avg-rtt=1ms max-rtt=28ms
  740 192.168.1.1                                56 255 0ms
  741 192.168.1.1                                56 255 0ms
  742 192.168.1.1                                56 255 0ms
  743 192.168.1.1                                56 255 2ms
  744 192.168.1.1                                56 255 0ms
  745 192.168.1.1                                56 255 0ms
  746 192.168.1.1                                56 255 0ms
  747 192.168.1.1                                56 255 0ms
  748 192.168.1.1                                56 255 0ms
  749 192.168.1.1                                56 255 0ms
  750 192.168.1.1                                56 255 0ms
  751 192.168.1.1                                56 255 0ms
  752 192.168.1.1                                56 255 0ms
  753 192.168.1.1                                56 255 0ms
  754 192.168.1.1                                56 255 0ms
  755 192.168.1.1                                56 255 0ms
  756 192.168.1.1                                56 255 3ms
  757 192.168.1.1                                56 255 4ms
  758 192.168.1.1                                56 255 0ms
  759 192.168.1.1                                56 255 0ms
    sent=760 received=760 packet-loss=0% min-rtt=0ms avg-rtt=1ms max-rtt=28ms
  760 192.168.1.1                                56 255 0ms
  761 192.168.1.1                                56 255 0ms
  762 192.168.1.1                                56 255 0ms
  763 192.168.1.1                                56 255 0ms
  764 192.168.1.1                                56 255 0ms
  765 192.168.1.1                                56 255 0ms
  766 192.168.1.1                                56 255 0ms
  767 192.168.1.1                                56 255 0ms
  768 192.168.1.1                                56 255 0ms
  769 192.168.1.1                                56 255 5ms
  770 192.168.1.1                                56 255 0ms
  771 192.168.1.1                                56 255 0ms
  772 192.168.1.1                                56 255 0ms
  773 192.168.1.1                                56 255 0ms
  774 192.168.1.1                                56 255 0ms
  775 192.168.1.1                                56 255 0ms
  776 192.168.1.1                                56 255 0ms
  777 192.168.1.1                                56 255 24ms
  778 192.168.1.1                                56 255 0ms
  779 192.168.1.1                                56 255 0ms
    sent=780 received=780 packet-loss=0% min-rtt=0ms avg-rtt=1ms max-rtt=28ms
  780 192.168.1.1                                56 255 2ms
  781 192.168.1.1                                56 255 4ms
  782 192.168.1.1                                56 255 0ms
  783 192.168.1.1                                56 255 0ms
  784 192.168.1.1                                56 255 0ms
  785 192.168.1.1                                56 255 0ms
  786 192.168.1.1                                56 255 11ms
  787 192.168.1.1                                56 255 0ms
  788 192.168.1.1                                56 255 0ms
  789 192.168.1.1                                56 255 0ms
  790 192.168.1.1                                56 255 13ms
  791 192.168.1.1                                56 255 0ms
  792 192.168.1.1                                56 255 0ms
  793 192.168.1.1                                56 255 0ms
  794 192.168.1.1                                56 255 2ms
  795 192.168.1.1                                56 255 0ms
  796 192.168.1.1                                56 255 0ms
  797 192.168.1.1                                56 255 0ms
  798 192.168.1.1                                56 255 0ms
  799 192.168.1.1                                56 255 0ms
    sent=800 received=800 packet-loss=0% min-rtt=0ms avg-rtt=1ms max-rtt=28ms
  800 192.168.1.1                                56 255 0ms
  801 192.168.1.1                                56 255 0ms
  802 192.168.1.1                                56 255 0ms
  803 192.168.1.1                                56 255 0ms
  804 192.168.1.1                                56 255 0ms
  805 192.168.1.1                                56 255 4ms
  806 192.168.1.1                                56 255 0ms
  807 192.168.1.1                                56 255 0ms
  808 192.168.1.1                                56 255 0ms
  809 192.168.1.1                                56 255 0ms
  810 192.168.1.1                                56 255 0ms
  811 192.168.1.1                                56 255 0ms
  812 192.168.1.1                                56 255 0ms
  813 192.168.1.1                                56 255 0ms
  814 192.168.1.1                                56 255 0ms
  815 192.168.1.1                                56 255 0ms
  816 192.168.1.1                                56 255 0ms
  817 192.168.1.1                                56 255 0ms
  818 192.168.1.1                                56 255 0ms
    sent=819 received=819 packet-loss=0% min-rtt=0ms avg-rtt=1ms max-rtt=28ms
and this is a test from 3750e -> CCR 1009 over SFP+ port :
Sending 1000, 100-byte ICMP Echos to 192.168.1.2, timeout is 2 seconds:
Success rate is 100 percent (1000/1000), round-trip min/avg/max = 1/3/34 ms
and also i do the same test over ethernet cable (connect CCR1009-Ethernet1 -> Cisco 3750e Ethernet 1) and result was same.
i ask this from mikrotik support they told me this is not critical but it should be solved before use it in production environment and they suggest me upgrade mikrotik to latest firmware and i did that but result was same! after many emails they told me its better ask cisco support because this issue is not related to their product.
and in these tests i change my 3750e-48td-s to another device (i have 2x 3750e-48td-s) and again result was same.
i also change transvier in 3750e-48td-s to another modules and result was same again.
so my question is :
1. is these pings are normal for point to point pings ?
2. in this situation can i use these routers and switches under production environment?
thanks,
7 Replies 7
I might be missing your point, but there is no packet loss, and response time seem ok ?
Either way, what is the uptime of the Cisco switch ? If it has been up for a long time (> 1 or 2 years), it can become slow to respond...
Post the 'show version' of the Cisco....
yes there is no packet loss the only issue is ping time is between 0~5ms and sometimes there is one packet with 50ms OR 100ms after 50-100 packet with 0~5ms
so i want know is it normal or not?
and my cisco uptime is 3 hours right now because i do not use this device under productuion enviroment. i want fully test it before use it in productuion enviroment.
as you see my ping soutputs are they fine and ok for productuion enviroment ? (because sometimes there is 1 packet woith 100ms ot 50mb ) and in point to point ping (from router to switch or vice versa) my max ping time is around 30ms (you can see output in first post)
and this is my show version :
Cisco IOS Software, C3750E Software (C3750E-UNIVERSAL-M), Version 12.2(44)SE2, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 01-May-08 11:41 by antonino
Image text-base: 0x00003000, data-base: 0x02000000
ROM: Bootstrap program is C3750E boot loader
BOOTLDR: C3750E Boot Loader (C3750E-HBOOT-M) Version 12.2(44r)SE3, RELEASE SOFTWARE (fc3)
Switch uptime is 1 hour, 12 minutes
System image file is "flash:c3750e-universal-mz.122-44.SE2.bin"
License Level: ipbase
License Type: Permanent
Next reload license Level: ipbase
cisco WS-C3750E-48TD (PowerPC405) processor (revision F0) with 0K/16376K bytes of memory.
Processor board ID X
Last reset from power-on
1 Virtual Ethernet interface
1 FastEthernet interface
52 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 54:75:D0:2C:C6:00
Motherboard assembly number : 73-11175-12
Motherboard serial number : X
Model revision number : F0
Motherboard revision number : B0
Model number : WS-C3750E-48TD-S
Daughterboard assembly number : 800-29737-01
Daughterboard serial number : FDO141303AJ
System serial number : FDO1350R1M9
Top Assembly Part Number : 800-28920-01
Top Assembly Revision Number : D0
Version ID : V03
CLEI Code Number : COM9V10ARB
Hardware Board Revision Number : 0x00
Switch Ports Model SW Version SW Image
* 2 54 WS-C3750E-48TD 12.2(44)SE2 C3750E-UNIVERSAL-M
Configuration register is 0xF
thanks
I don't think it's a problem. ICMP traffic is treated as low priority. That said, post the output of ''show proc cpu' to make sure there are no processes hogging CPU resources...
here is the output of show proc cpu :
Switch>show proc cpu
CPU utilization for five seconds: 7%/0%; one minute: 7%; five minutes:
so in this situation your idea all things is fine and i can use this router and switches under production enviroments right? there is nothing critical and ping times are normal for point to point ping?
thanks,
you should be fine. CPU utilization is low. The PING responses might simply be due to Mikrotik and Cisco using different default ICMP packet sizes...
so your idea is allthings is fine and we can use this in production network without problem?
thanks
Your question was about the PING response times. Those are not a problem when deloying the switch. I don't know anything else about your hardware, such as where and when you purchased it, if you have a service contract etc.
