Ping to C9000 series switches
charliegray
just like to check.
i ping a local loopback address configure on C9500 switch and received a few timeout.
same test repeat on C9300 and C9400 and got same result.... is this normal?
Giuseppe Larosa
Hello Charlie,
your switches may have configured by default Control Plane Policing and that could be rate limiting ICMP traffic.
see the following thread telling about autoCOPP and how to remove it.
https://community.cisco.com/t5/routing/auto-copp-policy/td-p/2350382
note: instead of removing it you can increase the policing rate for ICMP traffic
Hope to help
Giuseppe
pieterh
local loopback: you mean within the same switch to a locally configured loopback address?
the loopback address may be separated by VRF's, you need to supply more config info to tackle this issue.
you can try to ping while specify source address in the same vrf
