Pinging from ASA inside network to Remote inside network ERROR
ofjob7001
Are there any restrictions on ASA 5505 series?
I am not able to ping the remote site hosts from ASA inside network.
ASA Inside network : 192.168.10.0/24
Remote network (Using IPN4G Cell ) - 192.168.100.0/24
ASA hosts (inside network) is able to ping its gateway and the remote WAN IP. But "Requests time out" error appears when trying to ping from ASA inside network to IPN4G Remote network.
VPN is established. But pinging is giving error.
Need experts guidance
Are you specifying the inside interface when sending the ping?
ping inside 192.168.100.x
Yes, i did. I even tried "management interface inside" command. Still, didn't work out
I am able to ping inside interface (GATEWAY) of the ASA.
But pinging the remote site device (subnet) gives error "Request timeout".
I am not sure, if ASA 5505 series has some restrictions on it by default (that cannot be changed) :/ ?
