Pinging problem
arifbaqi19
Community Member
Hi, We have ISA sever having two NIC the IP address as following : the first NIC 192.168.2.1 , connected directlay to coreswitch 192.168.100.254 the second NIC 10.10.10.3 connected dierectly to internet router 2800 ,  f0/0 10.10.10.1  the problem when i am treying to ping from my PC whic is the IP address is 192.168.100.12 to internet router 10.10.10.1 , it is not pinging but i can telnet . please i need your assistance .  waiting for your relpy  thanks,
19 Replies 19
Thanks ,
This server is controlling  internet for all Vlan's , my question ,
Why all Vlan's can get internet with that it is in switch port mode ?
As Divin suggested,
Can you share the results of the following
From the PC
ping 192.168.100.12
ping 192.168.2.250
ping 192.168.100.253
ping 192.168.2.1
ping 10.10.10.1
ping 4.2.2.2
Please share the traceroutes as well to each of these.
Hi ,
Please check the attachment.
thanks,
waiting for your great solution, still the problem existing .
thanks,
Ganesh Hariharan
Hi Arif,
ISA server are build in firewall by default, I have seen the topology with ISA having two nic one with 10.10.x.x ip and other with 192.168.2.x but it is connected to core switch 192.168.100.x how is the connectivity is there and what is the routing configuration for 192.168.100.x in ISA server i mean reverse route where it is pointing out.
And for icmp allow by default ISA block you need to enable by deploying the policy check out the below link for more information on icmp enablement in ISA.
http://www.isaserver.org/tutorials/Configuring_ISA_Server_for_Incoming_Ping_Responses__By_Dieter_Rauscher.html
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
