Pinpoint Switch Bottleneck
ZackC
Community Member
This question is largely academic in nature - I have an OLD Cisco 2950 switch that is passing an increasingly high level of traffic and I'm certain that it's bottle-necking my network, but how would I prove that? I'm replacing the switch with a new gigabit unit next week, but how could I have identified this performance issue via metrics?
The switch is 10/100, with a pair of gigabit ports, and all of the traffic that is flowing through it internet-type of traffic (5-40mbps, from various ISP's, firewalls, DMZ, etc.) The traffic is segregated through numerous VLAN's, but otherwise there is nothing extraordinary about the configs. In theory all of the traffic should be well within the specs of a 100Mbps switch.
However, there is DMZ traffic passing through this switch, which includes a lot of SQL queries (with very large result-sets) as well as some proprietary TCP connections that can return fair amounts of data.
We noticed that some of our traffic was getting retry errors, and we were not getting the full bandwidth capacity from our ISP's when traversing this switch. We reconfigured one of the paths to use the gigabit ports which helped that traffic (even though it's only a 40/40mbps circuit), and when I did that, I noticed that my console CLI slowed to a crawl - the 9600baud looked about like 1200baud.
I pulled some stats that I thought might be helpful, but I just don't find a smoking gun that PROVES that there's a problem with this switch. I've attached some snips that maybe will mean more to others than myself.
show int
GigabitEthernet0/1 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 001f.279a.9f99 (bia 001f.279a.9f99)
  Description: InetNVT5
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
     reliability 255/255, txload 1/255, rxload 2/255
  Keepalive set (10 sec)
  Half-duplex, 100Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input never, output 00:00:00, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 1067000 bits/sec, 124 packets/sec
  5 minute output rate 156000 bits/sec, 93 packets/sec
     65554738 packets input, 55780401735 bytes, 0 no buffer
     Received 387 broadcasts (0 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     58780936 packets output, 36441903384 bytes, 0 underruns
     0 output errors, 714906 collisions, 1 interface resets
     0 unknown protocol drops
     0 babbles, 563592 late collision, 0 deferred
     0 lost carrier, 0 no carrier, 0 pause output
GigabitEthernet0/2 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 001f.279a.9f9a (bia 001f.279a.9f9a)
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
  5 minute input rate 156000 bits/sec, 92 packets/sec
  5 minute output rate 1067000 bits/sec, 125 packets/sec
     58572674 packets input, 36779751576 bytes, 0 no buffer
     Received 6 broadcasts (0 multicasts)
     65790467 packets output, 55792984590 bytes, 0 underruns
     0 output errors, 1926 collisions, 1 interface resets
     0 babbles, 3598 late collision, 0 deferred
show int counter
Port            InOctets    InUcastPkts    InMcastPkts    InBcastPkts
Fa0/1      6280250775933     9231296959              0            639
Fa0/2            1070635           6603           1554           5357
Fa0/3      6710244949295     9488311808           1049           4172
Fa0/4              77414            598            162            137
Fa0/5      6237948903196    16471810463             33       10276718
Fa0/6     19997607446810    21191741146       56301631     3346178839
Fa0/7      1069327834239     2043086938       18932982       59688798
Fa0/8       164963391712      999996896            109           2786
Fa0/9              35921            169             73            161
Fa0/10    30015663681418    46248128747             87          10604
Fa0/11    40135624559468    51405591747             38        2249161
Fa0/12       35084583062      209872036             48            203
Fa0/13        7537226578       48714042            715           3054
Fa0/14        1516601936        1688149              0              2
Fa0/15     8970207000875    16010043012       24056240         762486
Fa0/16    28012264871851    45653370694      123913396      117415909
Fa0/17    14790057083901    29638689004      103454467       10811758
Fa0/18     3171459106800     6169817338        9832759       18191764
Fa0/19    130042520174114   122350475789     3041860602        6005082
Fa0/20     5405543208944    13116181191       37604590        1475890
Fa0/21       77592569004      378822460              0           8179
Fa0/22     1114541769744     1295099614        7520073         245742
Fa0/23     1267360939321     2085553221        1989578         332521
Fa0/24     1890512734704     3901137214       39040055         949204
Gi0/1        55869324831       65641471              0            387
Gi0/2        36794759394       58638793              0              6
Port           OutOctets   OutUcastPkts   OutMcastPkts   OutBcastPkts
Fa0/1      6711382043763     9488305658       17773818           8649
Fa0/2             869500           5516           5371            418
Fa0/3      6168937213911     9038719975       17771682           6122
Fa0/4              60522             34            893             13
Fa0/5     19731849145164    22088495995       74596357     3405867532
Fa0/6      5112038665722    15473760141       18926060       69961560
Fa0/7      1495555797961     1853090397       56298293     3356393936
Fa0/8      1395010160426     1291304330       35416404      439598513
Fa0/9             429799            131             21           6272
Fa0/10    39962102508917    51110968894            645        2252402
Fa0/11    29526835538711    46500257680            700          13841
Fa0/12      168201258610      268427142             61         955659
Fa0/13        5185626838       24719583             40        1060779
Fa0/14         432246260        1555913            730        2263015
Fa0/15    23816780973184    20756205026     2797702874      151503908
Fa0/16    53941853629018    52869111737     2697704913       34850530
Fa0/17    40513136195324    37670565471     2718203782      141455032
Fa0/18     8799986657308     7535337293     2811786674      134075422
Fa0/19    44537393134174    95331334270      347139380      150186526
Fa0/20    19208301030895    17832175464      657884877        4995227
Fa0/21     1841723422709      564665337     3388867008      156186829
Fa0/22      947878120482     1147558653      868714191       10560127
Fa0/23     2098800811261     2332341031      725084628        6769560
Fa0/24     4453444449215     4552655768      555145889        3140609
Gi0/1        36457052034       58075471         237226              6
Gi0/2        55882507436       65637965         237052            159
show int counter err
Port        Align-Err     FCS-Err    Xmit-Err     Rcv-Err  UnderSize  OutDiscards
Fa0/1               3        3996           0        9034          0            0
Fa0/2               0           0           0           0          0            0
Fa0/3               0           1           0           1          0         8608
Fa0/4               0           0           0           0          0            0
Fa0/5               0           8           0           8          0            0
Fa0/6               3           5           0           8          0            0
Fa0/7               0           0           0           3          3            0
Fa0/8              28         468           0         498          0            0
Fa0/9               0           0           0           1          0            0
Fa0/10              0   934203121           0   934203127          0            0
Fa0/11              0           0           0           0          0            0
Fa0/12              0        2197           0        2198          0            0
Fa0/13              0        1220           0        1220          0            0
Fa0/14              0           0           0           0          0            0
Fa0/15              0           1           0           1          0      2029748
Fa0/16              0           0           0           0          0      3481479
Fa0/17              0           0           0           2          0       103346
Fa0/18              0           0           0           4          0        29858
Fa0/19              0           0           0           0          0      2461307
Fa0/20              0           0           0           0          0            0
Fa0/21              0           1           0          14          0            0
Fa0/22              0           0           0           0          0            0
Fa0/23              0           1           0           1          0            0
Fa0/24              0           0           0           0          0            0
Gi0/1               0           0           0           0          0            0
Gi0/2               0           0           0           0          0            0
Port      Single-Col  Multi-Col   Late-Col  Excess-Col  Carri-Sen      Runts     Giants
Fa0/1              0          0          0           0          0          0          0
Fa0/2              0          0          0           0          0          0          0
Fa0/3       79569220   39013388  192542062       36797          0          0          0
Fa0/4              0          0          0           0          0          0          0
Fa0/5              0          0          0           0          0          0          0
Fa0/6              0          0          0           0          0          0          0
Fa0/7              0          0          0           0          0          3          0
Fa0/8              0          0          0           0          0          0          1
Fa0/9              0          0          0           0          0          0          0
Fa0/10             0          0          0           0          0          0       8062
Fa0/11             0          0          0           0          0          0          0
Fa0/12             0          0          0           0          0          0          1
Fa0/13             0          0          0           0          0          0          0
Fa0/14             0          0          0           0          0          0          0
Fa0/15             0          0          0           0          0          0          0
Fa0/16             0          0          0           0          0          0          0
Fa0/17             0          0          0           0          0          0          0
Fa0/18             0          0          0           0          0          0          0
Fa0/19             0          0          0           0          0          0          0
Fa0/20             0          0          0           0          0          0          0
Fa0/21             0          0          0           0          0          0          0
Fa0/22             0          0          0           0          0          0          0
Fa0/23             0          0          0           0          0          0          0
Fa0/24             0          0          0           0          0          0          0
Gi0/1         448854     267509     563956         302          0          0          0
Gi0/2           1262        664       3598           0          0          0          0
show process cpu
CPU utilization for five seconds: 5%/0%; one minute: 5%; five minutes: 5%
 PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
   1           0           8          0  0.00%  0.00%  0.00%   0 Chunk Manager
   2      331833    31121683         10  0.00%  0.00%  0.00%   0 Load Meter
   3         509     1339884          0  0.00%  0.00%  0.00%   0 DHCPD Timer
   4   168749632    24332472       6935  0.00%  0.07%  0.05%   0 Check heaps
   5     7701613     2593475       2969  0.15%  0.01%  0.00%   0 Pool Manager
   6           0           1          0  0.00%  0.00%  0.00%   0 DiscardQ Backgro
   7           0           2          0  0.00%  0.00%  0.00%   0 Timers
   8           9         270         33  0.00%  0.00%  0.00%   0 WATCH_AFS
   9           0           1          0  0.00%  0.00%  0.00%   0 HRPC asic-stats
  10           0           1          0  0.00%  0.00%  0.00%   0 Crash writer
  11           0           1          0  0.00%  0.00%  0.00%   0 Exception contro
  12           0           1          0  0.00%  0.00%  0.00%   0 ARP Input
  13       78657   161504522          0  0.00%  0.00%  0.00%   0 ARP Background
  14           0           1          0  0.00%  0.00%  0.00%   0 AAA_SERVER_DEADT
  15           0           1          0  0.00%  0.00%  0.00%   0 Policy Manager
  16           8           3       2666  0.00%  0.00%  0.00%   0 Entity MIB API
  17           0           1          0  0.00%  0.00%  0.00%   0 IFS Agent Manage
  18       30289    31072050          0  0.00%  0.00%  0.00%   0 IPC Event Notifi
  19         463     2593313          0  0.00%  0.00%  0.00%   0 IPC Dynamic Cach
  20           0           1          0  0.00%  0.00%  0.00%   0 IPC Session Serv
  21           0           1          0  0.00%  0.00%  0.00%   0 IPC Zone Manager
  22       40337   151213854          0  0.00%  0.00%  0.00%   0 IPC Periodic Tim
  23       35993   151213854          0  0.00%  0.00%  0.00%   0 IPC Deferred Por
  24           0           1          0  0.00%  0.00%  0.00%   0 IPC Process leve
  25           0           1          0  0.00%  0.00%  0.00%   0 IPC Seat Manager
  26        1531     8888327          0  0.00%  0.00%  0.00%   0 IPC Check Queue
  27           0           1          0  0.00%  0.00%  0.00%   0 IPC Seat RX Cont
  28           0           1          0  0.00%  0.00%  0.00%   0 IPC Seat TX Cont
  29        4290    15560845          0  0.00%  0.00%  0.00%   0 IPC Keep Alive M
  30        6562    31072426          0  0.00%  0.00%  0.00%   0 IPC Loadometer
  31           0           3          0  0.00%  0.00%  0.00%   0 PrstVbl
  32           0           2          0  0.00%  0.00%  0.00%   0 XML Proxy Client
show process mem
Processor Pool Total:   21831860 Used:   16535464 Free:    5296396
I/O Pool Total:    4194304 Used:    2370532 Free:    1823772
Driver te Pool Total:    1048576 Used:         40 Free:    1048536
 PID TTY  Allocated      Freed    Holding    Getbufs    Retbufs Process
   0   0   19719052    3248840   13682576          0          0 *Init*
   0   0      12044     272416      12044          0          0 *Sched*
   0   0   28935876   27665384    1277852    2617230     263240 *Dead*
   0   0          0          0     394528          0          0 *MallocLite*
   1   0       1544       1544       7160          0          0 Chunk Manager
   2   0        232        232       4160          0          0 Load Meter
   3   0          0          0       7032          0          0 DHCPD Timer
   4   0       4652        232      11632          0          0 Check heaps
   5   0  726593020  726746236      42192 1851459116 1851504332 Pool Manager
   6   0          0          0       7160          0          0 DiscardQ Backgro
   7   0        232        232       7160          0          0 Timers
   8   0          0          0       4160          0          0 WATCH_AFS
   9   0          0          0       7160          0          0 HRPC asic-stats
  10   0          0          0      25160          0          0 Crash writer
  11   0        340          0       7500          0          0 Exception contro
  12   0          0          0       7160          0          0 ARP Input
  13   0        688        688       7160          0          0 ARP Background
  14   0          0          0       7160          0          0 AAA_SERVER_DEADT
  15   0          0          0      13160          0          0 Policy Manager
  16   0      24332       7564      23928          0          0 Entity MIB API
  17   0          0          0       7160          0          0 IFS Agent Manage
  18   0          0          0       7160          0          0 IPC Event Notifi
  19   0          0          0       7160          0          0 IPC Dynamic Cach
  20   0          0          0       7160          0          0 IPC Session Serv
  21   0          0          0       7160          0          0 IPC Zone Manager
  22   0          0          0       7160          0          0 IPC Periodic Tim
  23   0          0          0       7160          0          0 IPC Deferred Por
  24   0          0          0       7160          0          0 IPC Process leve
  25   0       1688          0       8848          0          0 IPC Seat Manager
  26   0          0          0       7160          0          0 IPC Check Queue
  27   0          0          0       7160          0          0 IPC Seat RX Cont
  28   0          0          0       7160          0          0 IPC Seat TX Cont
  29   0          0          0       7160          0          0 IPC Keep Alive M
  30   0          0          0       7160          0          0 IPC Loadometer
8 Replies 8
Georg Pauwen
first of all, make sure you got the basics covered. You have collisions on some interfaces, those alone can slow down the switch considerably. Nothing should be half duplex, everything should be full duplex.
GigabitEthernet0/1 is up, line protocol is up (connected) Hardware is Gigabit Ethernet, address is 001f.279a.9f99 (bia 001f.279a.9f99) Description: InetNVT5 MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec, reliability 255/255, txload 1/255, rxload 2/255 Encapsulation ARPA, loopback not set Keepalive set (10 sec) Half-duplex, 100Mb/s, media type is 10/100/1000BaseTX
johnd2310
Level 11
Level 11
For starter, your Gi0/1 interface is half-duplex/100mb and there are a lot of collisions and late collisions. You need to ensure Gi0/1 is running full-duplex/100.
There are a lot of error on your Fast Ethernet ports. You need to check the duplex/speed and cabling/nic.
John
**Please rate posts you find helpful**
ZackC
Community Member
I noticed that half-duplex setting.  The appliance that this switch is plugged into has multiple NIC's on it, and they're tied to separate VLANs.  Basically, the appliance is an internet service aggregator and so it connects our LAN to 2+ ISP's.  The two half-duplex connections are that appliance, but only the one in the Gig ports (which were previously in the FastEth ports and exhibited the exact same behavior) are actually affected.  The secondary ISP runs at full speed.
FWIW, the appliance says "100-Full Duplex", but according to the switch, that's not what it's actually doing.  I didn't realize that until after I took these grabs.  When I changed the Gig connection to "Auto Detect" on the appliance the problems went away, but simultaneously the console connection slowed to a crawl.
I don't have access to the switch this weekend to pull more data, but I'll try to grab that Monday before I swap out the switch.
Besides lots of framing errors, and a slow console connection, the only measurable behavior that I can actually document is speed tests on the 40/40mbps come back at 6mbps down, 35mbps up.  The other ISP that is also half-duplex, is a 25/5mbps, and the speed tests read almost exactly that.  Aside from that, I'm having weird, glitchy timeout issues on some SQL and proprietary TCP connections that are running between my VMWare hosts and the DMZ leg of the firewall.
2950 switch is really bad when it comes to "auto-negotiation".
Leo Laohoo
Gi 0/1 & Fa 0/3 are both running on Half-Duplex. Look at the amount of collision for Fa 0/3 and compare that value with Gi 0/1.
If I remembered the behaviour of a 2950, half-duplex errors should be spamming the logs constantly.
Post the complete output to the command "sh interface Fa 0/3 controll".
ZackC
Community Member
Output from sh int fa 0/3 controller
FastEthernet0/3 is down, line protocol is down (notconnect)
Hardware is Fast Ethernet, address is 001f.279a.9f83 (bia 001f.279a.9f83)
Description: InetNVT3
Auto-duplex, Auto-speed, media type is 10/100BaseTX
Last input 1y8w, output 1w2d, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 8608
9488317029 packets input, 6710244949295 bytes, 0 no buffer
Received 5221 broadcasts (1049 multicasts)
1 input errors, 1 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 1049 multicast, 0 pause input
9243040178 packets output, 6168937213911 bytes, 0 underruns
0 output errors, 118619405 collisions, 1 interface resets
7 unknown protocol drops
0 babbles, 192542062 late collision, 0 deferred
Transmit FastEthernet0/3 Receive
1364176855 Bytes 1506032943 Bytes
448785383 Unicast frames 898377216 Unicast frames
17771682 Multicast frames 1049 Multicast frames
6122 Broadcast frames 4172 Broadcast frames
0 Too old frames 1505649430 Unicast bytes
151955080 Deferred frames 91402 Multicast bytes
0 MTU exceeded frames 291744 Broadcast bytes
79569220 1 collision frames 0 Alignment errors
17457768 2 collision frames 1 FCS errors
5775046 3 collision frames 0 Oversize frames
3400428 4 collision frames 0 Undersize frames
2645405 5 collision frames 0 Collision fragments
2222959 6 collision frames
2210691 7 collision frames 1410039121 Minimum size frames
2058562 8 collision frames 1439453258 65 to 127 byte frames
1672889 9 collision frames 1663826970 128 to 255 byte frames
1073288 10 collision frames 601915795 256 to 511 byte frames
319078 11 collision frames 281894942 512 to 1023 byte frames
105369 12 collision frames 4091186944 1024 to 1518 byte frames
41903 13 collision frames 0 Overrun frames
19492 14 collision frames 0 Pause frames
10510 15 collision frames
36797 Excessive collisions 0 Symbol error frames
192542062 Late collisions 0 Invalid frames, too large
0 VLAN discard frames 0 Valid frames, too large
0 Excess defer frames 0 Invalid frames, too small
1963333898 64 byte frames 0 Valid frames, too small
1182820777 127 byte frames
1400428239 255 byte frames 0 Too old frames
726202400 511 byte frames 0 Valid oversize frames
448661982 1023 byte frames 0 System FCS error frames
3521592882 1518 byte frames 0 RxPortFifoFull drop frame
0 Too large frames
79569220 Good (1 coll) frames
39013388 Good (>1 coll) frames
As the others have noted, you do want to investigate your "half duplex" running ports. Half-duplex, especially on a single port, if truly running half duplex should be much of a problem (although best avoided, if not required), but if one device is running a port at full-duplex and the other side is running half-duplex, that's very, very bad for performance.
This is a red herring everyone.
Port has been down for > 1 year.
