10-27-2010 06:49 AM - edited 03-06-2019 01:45 PM
Problem: I have a analog door phone connected to a port in my FXS card in my 2911 gateway. The gateway is an MGCP gateway running on a CUCM BE ver. 7.1
The PLAR functionality is working and the expected IP phone is ringing but when i hang-up the IP phone the PLAR is still activated and the phone rings again and again and again.
How can i get the IP phone to terminate the call?
kind regards
Niels
10-30-2010 01:06 PM
What PLAR connection are you using?
Try "connection plar opx".
You can set also a "supervisory disconnect" command under voice-port.
I use this configuration without problem:
voice class dualtone-detect-params 1
freq-max-deviation 25
freq-max-power 0
freq-min-power 13
freq-power-twist 4
cadence-variation 4
voice class custom-cptone UAE-CUSTOM-ALCATEL
dualtone disconnect
frequency 425
cadence 375 375
voice-port 1/0
supervisory disconnect dualtone mid-call
supervisory custom-cptone UAE-CUSTOM-ALCATEL
input gain -5
output attenuation 0
no non-linear
no vad
playout-delay nominal 100
playout-delay mode fixed
cptone IT
timeouts interdigit 5
timeouts call-disconnect 1
timeouts wait-release 1
timing guard-out 300
connection plar opx 502
10-31-2010 07:44 AM
i havn't done anything to the gateway except setting it up via MGCP and the CCM. The port is set as an POTS port and thats it. The door phone i an using is of an unknown manufacture.
I will try with the "connection plar opx"
regards Niels
12-01-2010 12:39 AM
I've the same issue with a VG224 using MGCP.
Did you solve your issue?
Thank you
Best regards
