11-17-2020 11:04 AM - edited 11-17-2020 11:06 AM
I can't open cisco packet tracker in any way. This error appears after installation. Please help to fix this problem.
Solved! Go to Solution.
11-18-2020 12:55 PM
I see your picture now; download PT again from straight from NetAcademy (do not use other sources), choose 32 or 64 bit version that matches your Windows,
Regards, ML
**Please Rate All Helpful Responses **
11-17-2020 02:03 PM
Cannot open a attached picture; There should be no PT issues on Windows while a few issues installing PT on Linux-based machine. Some other issues (running) with PT on Mac PC. For now, I would recommend try it again or contact PT people via link below.
As Always, you can use Windows PC.
https://app.smartsheet.com/b/form/e8051c092e07401aa7d50ec2424a6e1c/
Regards, ML
11-17-2020 11:27 PM
hi,
the error mentioned an incompatible windows version.
which windows version are you trying to install PT?
you could alternatively run a windows VM (mostly likely windows 7) and install PT there.
11-18-2020 12:55 PM
Regards, ML
