Please help me to select a Cisco core-switch!
l_masoumi
Hi all,
Anybody can help me to select a proper Cisco Core-Switch?
Some of the needed specifications are below:
1- At least 08 Gbit Ethernet - RG45 copper connector
2- At least 12 fiber gigabit module bases
3- At least 12 Gigabit Ethernet Fiber ports (Populated)
4- Manageable Gigabit Ethernet Net Switch with layer 2, 3 and 4 services
5- Modular chassis basis architecture
6- Layers 2 through 4 hardware-based switch engine (ASIC-based)
7- Hardware based ACLs, router ACLs, VLAN ACLs
8- Protocols: Support for IPv6RIPv1, RIPv2 routing function. support for EIGRP-stub. Hot Standby Router Protocol. IGMP vers 1,2,3.
10- Forwarding bandwidth: Scalable upto 64 Gbps or higher...
11- MAC support up to 32000 MAC or more...
Any information, ideas, guidance or link to make the decision easier will be appreciated.
Thank you in advance...
Cheers!
Lad.
6 Replies 6
n.nandrekar
Level 4
Level 4
Hi!
A Catalyst 6500 can meet all your requirements.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/product_at_a_glance0900aecd806a09f2.pdf
Please rrevert if you require any more specific info.
Niranjan
Hi Niranjan
Thank you for help... I found WS-C6503-E product to be the one I need.. but still not really clear about how many ports and which type of ports this product already has(without adding any module to it). I thought I might need to add a module to 6503 chassis, to be able to have 12 Gigabit Ethernet fiber ports, but not sure if I'm correct?!
I went through the data sheets and tried to understand these things but unsuccessful.
One more, I believe for the rest of my requirement I need to add Supervisor Engine 720 module to this chassis which will occupy 2 slots out of 3 available. Then for having 12 Gigabit Ethernet Fiber ports, if adding a module is the solution, will that one slot be enough?
Thanks again for the help.
Best Regards,
Lad.
Joseph W. Doherty
Besides the 6500, the 4500 series might be suitable, see http://www.cisco.com/en/US/products/hw/switches/ps4324/index.html
Thanks Joseph for help.. I think I better go for Catalyst 6503-E according to the other requirements I have.
Jagdeep Gambhir
Level 10
Level 10
Lad,
Go for Cisco Catalyst 6500
http://www.cisco.com/en/US/products/hw/switches/ps708/index.html
~JG
Thanks JG for help.. I think you are right.
