Please help me to understand this Q
Amr Ali
Hello Sirs,
Kindly i need help to understand this question
Best regards - amr
InayathUlla Sharieff
Whats the query?
Jan Rolny
Level 3
Level 3
Hi Amr,
answer is: because auto-summary is turned on. Network 172.16.5.x /28 is summarized to 172.16.0.0 network. You need to configure no auto-summary command to let router know about "remote/neighbor networks".
auto-summary tells your router that only classful subnetmasks (255.255.0.0 in this case) will be used.
Also please read this document where it is litle bit explained:
http://www.ciscopress.com/articles/article.asp?p=174107&seqNum=3
Jan
Sandeep Choudhary
Hi Amr,
This Command: show ip route  on RouterB shows that Router B did not learn the network from Router A.
It only learn which is directly connected to Router B menasnetwork is summarized as also shoes by 00:00:03, Null0″ line
or
If you look carefully at the R2 ip route, you will discover that the R2 does not learn any network from R1; this is because the routing protocol used here (EIGRP) performs auto summary when advertising routes to peers across a network. So in this case the address 172.17.0.0/26 is a summarized address. If the router was configured with no auto summary command, R2 LAN addresses would have been advertised and reached.
Hope it helps.
Amr Ali
Thanks experts for your efforts
