Please help me to understand
Amr Ali
Hello Sirs,
Kindly i need help to understand this question " at attachment " , as i think answer C is more reliable
Best regards - amr
Leo Laohoo
Nope.  The answer is neither correct or wrong.
It's both A & C.
And the question is misleading.  Let me explain:
C is valid if you are dealing, for example, 2900/3500, 2940/2950/2955 and even 6500 (not sure about the old supervisor cards of the 4500/4000).  If you don't create the VLANs in the VLAN database, the interface VLAN will remain down/down.
A is valid if you're dealing with the newer switches like the 2960, 3560, 3750, 3850.  I can't tell with the 2350 and the 2650/2750.
However, if this is a Cisco certification exam, I'll go with "C".
5 Replies 5
Leo Laohoo
It's both A & C.
Special thanks to you mr. leolaohoo , however i am very confused
You are still confused?  Let me explain further, not technical anyway.
When you are taking the certification tests, what you know from the "wild" is irrelevant.  What you learn from the courses is more important in the wild.
Even though option A is correct (in the wild), when it comes to the certification exams, option A is deemed incorrect.
The foundation concept, when configuring VLANs is being re-inforced here:  Create the VLAN in the VLAN database and then create the interface VLAN.  This must be followed during the exam
Thanks leolaohoo for clarification , best regards
leolaohoo gives very good explanation. answer A is correct if you are going for certification.
