po
KAN41R
Mark Malone
There DTP errors turn off negotiate (switchport nonnegotiate ) under the interfaces when there trunk
would help if you posted the configs your applying as might be something else but usually its a negotiating issues causing that alert
the command show interface gx/x switchport for each interface will show you the diffs
Thanks Mark. Cheers!!!
Carlos Villagran
Hi!
One of the ports in your port-channel is configured as access with switchport mode access. Please verify the configurations of the ports and as Mark stated you can use show int gig x/x switchport in order to verify differences.
Hope it helps, best regards!
JC
Thank you carlos. Have corrected it.
