poe is not working on WS-X6748-SFP.
Shabeer E
Hi All,
I am trying to connect poe device on WS-X6748-SFP port, it showing inline power not supported.
It means this module not support POE or I have to enable something...
Appreciate if any one can help on this.. Thanks!
ABCD#sh power inline gi1/4/8
Interface Gi1/4/8: inline power not supported
ABCD#show power
system power redundancy mode = redundant
system power total =     5771.64 Watts (137.42 Amps @ 42V)
system power used =      1456.98 Watts (34.69 Amps @ 42V)
system power available = 4314.66 Watts (102.73 Amps @ 42V)
                        Power-Capacity PS-Fan Output Oper
PS   Type               Watts   A @42V Status Status State
1    WS-CAC-6000W       5771.64 137.42 OK     OK     on
2    WS-CAC-6000W       5771.64 137.42 OK     OK     on
                        Pwr-Allocated  Oper
Fan  Type               Watts   A @42V State
1    WS-C6509-E-FAN      210.00  5.00  OK
                        Pwr-Requested  Pwr-Allocated  Admin Oper
Slot Card-Type          Watts   A @42V Watts   A @42V State State
2    WS-SVC-FWM-1        171.78  4.09   171.78  4.09  on    on
4    WS-X6748-SFP        292.74  6.97   292.74  6.97  on    on
5    VS-S720-10G         338.10  8.05   338.10  8.05  on    on
6    WS-X6708-10GE       444.36 10.58   444.36 10.58  on    on
system auxiliary power mode = off
system auxiliary power redundancy operationally = non-redundant
system primary connector power limit =   10920.00 Watts (260.00 Amps @ 42V)
system auxiliary connector power limit = 10500.00 Watts (250.00 Amps @ 42V)
system primary power used =              1456.98 Watts (34.69 Amps @ 42V)
system auxiliary power used =            0 WattTENANT-CORE-SWITCH#show power
                        Pwr-Allocated  Oper
Reza Sharifi
Fiber modules (SFP) do not support POE.  Only copper modules do.
for example this card support POE:
WS-X6548-GE-45AF
Have a look at table-7 in this link:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/product_data_sheet0900aecd8017376e_ps2797_Products_Data_Sheet.html
Reza Sharifi
WS-X6548-GE-45AF
I was trying to connect Cisco Access Point using GLCT to the port..
Thanks for your valuable information.
Sorry, it will not work with GLC-T.
Please rate and close the threat, so others can benefit from it.
Won't work because a GLC-T SFP module doesn't support PoE either.
The only way to get the WAP working is to either use a power injector or a power pack/power brick.
