PoE on Catalyst 2960 Series SI for PoE and 2950 Seriess
Awan
May I know if PoE is available on these two Cisco Switch PoE on Catalyst 2960 Series SI for PoE and 2950 Series?
I don't see the below command in the interface configuration mode:
Switch(config-if)#power inline ?
% Unrecognized command
5 Replies 5
balaji.bandi
some old code may not support some command, what is the IOS code running
show power inline should give you available power
BB
Awan
Thank you. Here is the version  12.1  on 2950.
Awan
Switch1>show version
IOS (tm) C2950 Software (C2950-I6Q4L2-M), Version 12.1(22)EA4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Wed 23-Mar-05 15:33 by yenanh
Image text-base: 0x80010000, data-base: 0x80562000
Awan
I understand the latest version is 12.1(22)EA14. Do I need to upgrade the IOS first?
These devices are end of life long back, may be i do not re-call command, if you have access the IOS and able to upgrade, then upgrade and test it.
BB
