poe+ working but not working for some devices
robertkwild
hi all,
i have a cisco 3850 POE+ switch and both kettle leads are connected in to them and both PSU lights say connected and ok
on a port i plug in a voip phone and it powers it up no problem
but as soon as i connect a door to the switch it doesnt power on the control panel for the door, but the door control panel says they need POE+, so i dont understand why there not powering on
can i maybe change the power to one of the ports?
thanks,
rob
5 Replies 5
It may need more power than the switch can provide out. You should be able to adjust the power on a per interface basis. If not there are devices that plug into a wall power outlet to check POE devices. IP phones have them if there is no POS switch or port in the area. Its like a power brick for ethernet. Test on that to see if it can get power from the wall.
-David
this is weird when i do a
show power inline
the ports where the poe+ devices are plugged in keep on changing ie one time they say on, then next they say off, so maybe theres not enough power
ammahend
Is lldp and cdp enabled ?
share show power inline and show inventory.
-hope this helps-
Gi1/0/42 static off 30.0 n/a n/a 30.0
Gi1/0/43 static on 30.0 Ieee PD 4 30.0
Gi1/0/44 static on 30.0 Ieee PD 4 30.0
Gi1/0/45 static off 30.0 n/a n/a 30.0
Gi1/0/46 static on 30.0 Ieee PD 4 30.0
Gi1/0/47 static off 30.0 n/a n/a 30.0
Gi1/0/48 static off 30.0 n/a n/a 30.0
NAME: "c38xx Stack", DESCR: "c38xx Stack"
PID: WS-C3850-48P-L , VID: V07 , SN: FCW2034F0CG
NAME: "Switch 1", DESCR: "WS-C3850-48P-L"
NAME: "Switch 1 - Power Supply A", DESCR: "Switch 1 - Power Supply A"
PID: PWR-C1-715WAC , VID: V01 , SN: LIT203237PE
NAME: "Switch 1 - Power Supply B", DESCR: "Switch 1 - Power Supply B"
PID: PWR-C1-715WAC , VID: V01 , SN: LIT19240UPS
NAME: "Switch 1 FRU Uplink Module 1", DESCR: "2x1G 2x10G Uplink Module"
PID: C3850-NM-2-10G , VID: V01 , SN: FOC203519VW
NAME: "Te1/1/4", DESCR: "SFP-10GBase-SR"
PID: SFP-10G-SR-S , VID: V01 , SN: AVD2030D59D
I changed back from static to auto, still no difference, it giving out 30w and max is 30w but it keeps on turning off and back on as when I do
Sh power inline
It keeps on showing as on and off so the power keeps on going on off
I have sort of resolved it by another switch
But I would like to get to the bottom of this
